LG B8 TV questions:
Popular Now
By The Old Man
Hey LG
Yes I am NOT happy
By Arthur Dent
1-Want to use Google meet, WebOS browser says not compatible, can’t install Firefox, chrome or edge browsers...is there a way to achieve this ?
2-can I use a webcam with a MIC with this TV ?
3- is there a way to disable the update popup reminder ? Don’t want to update as reports of big issues with the latest update thanks
By AnonViewer
I purchased a new 43" LG 4K TV in India couple of months ago. Model Number is 43UJ652t. I use Dish TV DTH service for watching TV. I connected my Dish TV HD Set Top Box to the TV through HDMI port (HDMI 1)
I have couple of questions -
When I select the HDMI input to watch TV, the following information is displayed on the top-left corner of the TV (See pic 1 below). It says 720p there. What does it mean? I have HD set top box with HD Channel subscription. Why is it saying 720p there even when I am watching HD channels? There is an Icon in the Web OS launcher called Live TV (see pic 2 below). It doesn't work with DTH set-top boxes? Does it only work with Antenna and Free to Air channels? The TV guide icon (see pic 3) in the Web OS launcher doesn't doesn't play the TV Guide for my Set-Top Box. It asks me to fine tune the programming first but Auto-tuning doesn't find any channels? Is the TV Guide functionality available only for the Antenna and FTA channels? Can I add channels from my set-top box to the My Channels menu (see pic 4)? How do I add shows from Amazon Prime to the "My Content" menu for easy access. Currently, it only allows me to add YouTube content Can I add a specific channel from my Dish TV set top box as a long press shortcut in my LG Magic Remote? In the below LG videos, when the presenter selected the STB while setting up Live TV, the TV automatically searches for the channels and populates the TV Guide? Is it not possible to do it for Indian DTH set top boxes?
These questions are driving me mad. Please help me in understanding the LG Web OS System better
By frpatte
Bonjour,
I just bought an LG TV: 43UM7450PLA and I have a few questions about the use of this TV.
1- On my home network, I have a DLNA server where are stocked films, music and photos. When I want to play music, sometimes the answer is: "there is no music files in that folder". Strange answer because there are music files in the folder and because sometimes this music is played without any complaint from the TV. How can I know why this answer (no music files...) is given? Are there some log files somewhere in the TV?
2- I often watch the TV via the internet navigator and it is very difficult to have a stable connection, the stream is often interrupted or stopped with a message error (an error occured, try again). If I watch the same TV stream at the same time on my computer, it works like a charm. Why this different behaviour on the TV?
Thank you for your lightd.
F.P.
By foxfire_pt
I like webos on my TV, but there are only two small anoying details that would be great if there is a way around it.
1. TV in Portugal Vodafone has still Cable and Antenna channels. Scanning is not a problem and quality is acceptable for the source. Those channels because they are analogue will not gain description and only show the frequency name such as "S34". Is there any way to rename the channel to something more human readable such as "RTP1" ?
2. Adding a bookmark from the web browser to the main screen works like a charm, but is there any way when lauching the bookmark from there in FullScreen and it doesn't show the intire browser ?
thanks
Trev
1. For well over a year the Antenna Channel Guide has been incomplete. Is there a way to manually update the guide?
The Prime app has suffered from two problems:
2. No subtitle option on movies, fixed by app uninstall/reinstall. Is there an easier fix?
3. 4K movies downgrade to SDR or SD momentarily, app uninstall/reinstall did NOT fix this?
TV software is upto date. Internet speed is good. Cache has been cleared by power disconnect/reconnect.
I have not tried Reset To Original settings, will that wipe out antenna channel & HDMI input name customizations?
Thanks.
