How internal subtitles are selected for MKV files?
If I play an MKV video from a USB drive that contains multiple subtitle tracks with correct language tags, will webOS automatically select the appropriate subtitles, for example based on the TV interface language or the country where the TV is being used? Or it will just select first one/makred as fefault?
When you see the file name on  the screen Use the subtitle icon on the lower left of the screen to open the subtitle box
Then you can select the subtitles you want to see
There is no default related to the tv settings
  • Popular Now
    • By Digard
      I know this was mentioned before. I'd like to support this.
      WebOS is such a great and versatile system; a real media centre. BUT: I have a number of video files that it simply doesn't play. VLC, e.g. does, but is not available.
      To me it is such a pity that I have to have a system in parallel (actually a PC!) to play those files, with VLC, and then switch to HDMI to watch the clips on my TV. This doesn't look very much like 2026, as far as I am concerned.
      To give an example, in which nothing is spectacular, and yet it doesn't play:
      Format                                   : AVI Format/Info                              : Audio Video Interleave Format settings                          : BitmapInfoHeader / WaveFormatEx File size                                : 360 MiB Duration                                 : 51 min 6 s Overall bit rate                         : 986 kb/s Frame rate                               : 23.976 FPS Writing application                      : VirtualDubMod 1.5.4.1 (build 2178/release) Writing library                          : VirtualDub build 24259/release Video ID                                       : 0 Format                                   : MPEG-4 Visual Format profile                           : Advanced Simple@L5 Format settings                          : BVOP1 Format settings, BVOP                    : 1 Format settings, QPel                    : No Format settings, GMC                     : No warppoints Format settings, Matrix                  : Default (H.263) Muxing mode                              : Packed bitstream Codec ID                                 : XVID Codec ID/Hint                            : XviD Duration                                 : 51 min 6 s Bit rate                                 : 752 kb/s Width                                    : 512 pixels Height                                   : 384 pixels Display aspect ratio                     : 4:3 Frame rate                               : 23.976 (24000/1001) FPS Color space                              : YUV Chroma subsampling                       : 4:2:0 Bit depth                                : 8 bits Scan type                                : Progressive Compression mode                         : Lossy Bits/(Pixel*Frame)                       : 0.160 Stream size                              : 275 MiB (76%) Writing library                          : XviD 1.1.0 (2005-11-22) Audio ID                                       : 1 Format                                   : AC-3 Format/Info                              : Audio Coding 3 Commercial name                          : Dolby Digital Codec ID                                 : 2000 Duration                                 : 51 min 6 s Bit rate mode                            : Constant Bit rate                                 : 224 kb/s Channel(s)                               : 2 channels Channel layout                           : L R Sampling rate                            : 48.0 kHz Frame rate                               : 31.250 FPS (1536 SPF) Compression mode                         : Lossy Delay relative to video                  : 23 ms Stream size                              : 81.9 MiB (23%) Alignment                                : Split across interleaves Interleave, duration                     : 42  ms (1.00 video frame) Interleave, preload duration             : 500  ms Service kind                             : Complete Main Dialog Normalization                     : -27 dB compr                                    : 0.53 dB dynrng                                   : 0.53 dB dialnorm_Average                         : -27 dB dialnorm_Minimum                         : -27 dB dialnorm_Maximum                         : -27 dB Please, add-on to media player whatever is necessary to play such files!
      Better yet: add something like VLC or at least Dragon. Make it available; even if the warranty was void, I'd prefer to load such an application.
      Thanks for pondering!
    • By ZealousFlamingo
      So basically I just got a new LG OLED TV (55 inch C5) and my Dad's C4 was seemingly able to display internal or embedded subtitles in TV shows through the built-in media player from external USB storage just fine with some tinkering in the menus.
      But with mine, the subtitles are displaying all of the raw text in the subtitle files in the player, not using the arguments properly at all.
      Pictures included for reference
      Is there any way to fix this other than literally doing subtitles for every episode externally, in a seperate file?
      These subtitles work fine when I play from the exact same storage device on my phone through VLC, and again on my Dad's LG TV
    • By MURAD
    • By John Peet
      TV is a week old and the internal speaker has stopped working when in HDMI ARC + internal speaker sound output mode. The internal speaker itself works fine when in “internal speaker” sound output mode. I’ve checked all the settings that I can and can’t find anything that would correct this issue.
    • By ACS
      Ive been having trouble with the ITVX app, when i open it it goes straight to itv1 but when i select another channel it still returns to itv1
      have spoken with itvx customer support for the past 3 months but they assue me its the LG TV software that controls this and not the app making changes when i select something.
      have emailed LG but had no useful reply just reinstall and try again!!!
      very frustrating, and the only way i can watch a channel is to select the next highest channel and then select the channel i want.
      please Help!!!!!!!!
