OLED48B56LA Internal speaker not working when using HDMI ARC + internal speaker sound output
Popular Now
By starwoodtech
By ALIENQuake
If I play an MKV video from a USB drive that contains multiple subtitle tracks with correct language tags, will webOS automatically select the appropriate subtitles, for example based on the TV interface language or the country where the TV is being used? Or it will just select first one/makred as fefault?
By NaveenKumar
Latest version of sun NXT app version 8.0.20 is not working for web os Tv version 4.4.2-11 plz do the needful full & Airtel Xstream is not found in your web os platform kindly check on that too
By jikhead
I'm not getting any audio from the apps via the HDMI via ARC connection to my receiver. This occurred two weeks ago and was unable to resolve it, but ironically there was new firmware released that same day for my B6 (3/31/17) and this fixed the issue. However, now I again can't get it working after a TV reset and tinkering with the audio settings again. I tried to load the firmware again, but it appears this is not possible to forceable load the same firmware.
By bohatier
TV model: OLED55B13LA
Example:
