LG C5 TV/Denon ARC/CEC issues
I have a Denon AVR hooked up to the HDMI 2 input on my LG tv. When I initially set it up, I was able to control the volume of the Denon receiver by using the LG remote. I enabled CEC Simplink and eARC on the TV and this allowed me to not only use the volume but also turn the receiver on and off automatically with the TV. Recently, my LG tv installed a software update and ever since that point, the TV reverts to TV Audio instead of HDMI 2 every time I turn the TV off and back on again. I then have to change the sound setting to HDMI and the volume control works perfectly.
Any tips? I already tried unplugging everything including the HDMI cables, turning CEC and eARK off and back on again, and reverting to all original settings but nothing seems to work.
My Denon receiver does not have eARC support, not sure if that matters but I'd love to know the best way to set it up to control volume through one remote.
5 answers to this question
My parents are having a similar issue on their OLED (a 2025 model). Different Brand Receiver though (Yamaha). It was working for about 10 days off the AT&T set top box HDMI 2, eArc connection to eArc connection on a brand new Yamaha receiver off the AT&T remote around Christmas. Now, parents are struggling to use 3 remotes (at&t, LG, yamaha) to get audio and picture going on each bootup.
Parent's have tried calling/working with LG Customer Support as the TV is still under warranty. Getting the run around are not Helpful. Best Buy hasn't been helpful yet either with Geek Squad either (where TV and receiver were purchased). AT&T says it's likely a TV issue, so they can't do much on their end.
Made an account on this forum just to let you know you are not alone. My C3 was having issues with it staying on after my Apple TV turned off a week ago. And now a couple days ago my TV can no longer control my eARC soundbar. My TV is on the latest webOS so I assume the update broke it. Definitely a lot of issues going on with CEC eARC, but I haven’t found a good solution yet
Very frustrating. Clearly tied to a recent update for the TV as the problem started happening right after the update.
So I ended up just turning off the breaker for my living room overnight. When I turned on my TV again, all the HDMI connections kind of reestablished themselves, and CEC was working perfectly again, I can control my soundbar now. Overnight and turning off the breaker is extreme, so maybe just turn off all power to devices and the TV for like 5+ minutes.
Update from my parents saga.
An LG CS rep came to the house and got things working again.. This lasted for a few weeks, and then the TV would just go a black screen after power up on HDMI 2 input where the eArc connection is to the Yamaha Receiver is.
Parents called up LG again and then were directed to call AT&T.
AT&T sends them a new cablebox (had to wait another few days for a tech to come out to install it) and now everything is working again.
Thing the source of all of this may have just been a super old/outdated AT&T set top box.
Will see if this finally fixes things.
  • Popular Now
    • By mesplint
      I have a LG 65QNED92AUA tv that has issues with the Bluetooth connection dropping off when connected to my earbuds. I believe the issue to be software related. LG has sent 2 technicians out to repair and the first technician changed the main board and Bluetooth transmitter which did not resolve the issue.
      There are similar issues with Bluetooth Connection from others.
      Since hardware replacement didn’t help and this is a known software-pattern issue, I would like push LG to specifically address it at the firmware/webOS level. I am unable to escalate to their software team and check if there’s a known patch or beta firmware for the QNED92 line.
      For some reason this line of questioning is not available with in LG customer service.
       Please help!
    • By Daniel Buxton
      Since updating our OLED65G2PSA to 23.20.56, we experience sprodadic issues with the network where any app requiring network access shows the generic 'no network access' message.
      I have found that when this does happen, I can still PING the TV and connect to IP based web pages.  To fix I can either power cycle the TV or I can go into network settings and toggle off/on 'Set automatically' which must just be triggering something in the underlying OS to reload its DNS service.
      Setting a static IP makes no difference, setting a static DNS server makes no difference - it is clearly a software issue.  We have had a TV repair company come and replace the boards, which worked right up untill updating to 23.20.56 and beyond.
      Has anyone else experienced this, does anyone have a solution ?
    • By swin
      TV: LG 55UJ630V
      OS Version: 5.80.50
      Problem: Spotify is laggy, stops occassionally and is basically a sub-prime experience.
      I can play 4K TV with Netflix, Amazon Prime etc absolutely fine, so why should an audio app have problems?
    • By akhil7j
      At Frieze London 2024, LG OLED and Akomfrah Bring Art and Technology
      Together to Inspire Audiences With a Thought-Provoking Film Installation
      SEOUL, Oct. 11, 2024 — LG Electronics (LG) has once again partnered with the widely respected artist and filmmaker, Sir John Akomfrah, for Frieze London 2024. This collaboration follows LG’s recent support of Akomfrah’s British Pavilion at the 60th International Art Exhibition at La Biennale di Venezia 2024. At Frieze London 2024, LG OLED has invited Akomfrah – an artist and filmmaker known for investigating themes such as memory, post-colonialism, temporality and aesthetics – to present a new video installation at the fair.
      Becoming Wind (2023) is a five-channel video installation that focuses on the intersection of social and environmental issues, looking specifically at the experience of non-binary and trans actors and activists in the context of the climate crisis. A profound meditation on identity formation is framed by an allegorical representation of the Garden of Eden and its disappearance; a montage of footage evoking the abundant richness of past biodiversity is interrupted by glimpses of blazing wildfires, scenes of racial discrimination and a fragmented text, underscoring responsibilities to confront multiple and intersecting crises.
      Powered by the compelling fusion of art and technology, multiple ultra-large LG OLED displays bring Akomfrah’s artistic narratives to life with stunning picture quality on an incredible scale. Notably, LG OLED’s self-lit nature reveals the full, vivid expression of the colors, enriching the depth and realism of the artwork’s multi-sensory elements for a truly immersive experience.
      LG’s commitment to making LG OLED a more sustainable choice closely aligns with Akomfrah’s drive to address climate change, human communities and the plight of migrant diasporas globally. LG OLED TVs incorporate fewer components than LCD TVs due to the absence of a backlight, which results in the 65-inch OLED TV using 60 percent less plastic compared to an LCD TV of the same size. Weighing in at about 20 percent less than an LCD TV of the same screen size, OLED screens also contribute to the reduction of CO2 emissions during transit. In addition, recycled plastic accounts for approximately 20 percent of the plastic used in the manufacturing of all LG TVs, including OLED models. These efforts have culminated in LG OLED TVs receiving environmental product certifications from the UK’s Carbon Trust and Switzerland’s SGS for four consecutive years, underscoring the company’s commitment to sustainability.*
      “I’m truly delighted to be able to bring my artistic vision to life with LG OLED,” said Akomfrah. “Becoming Wind aims to draw viewers into a deep state of contemplation about the intrinsic relationship between nature, humanity and technology through the interplay between sound and visuals. LG OLED’s advanced audiovisual capabilities and technological advancements enhance the sensory elements of the art, seamlessly integrating image, sound and emotion to take audiences on a visually compelling and intellectually stimulating journey.”
      “We are pleased to continue our collaboration with renowned artist Sir John Akomfrah to highlight how LG OLED captivates audiences by enhancing the depth of his thought-provoking artwork,” said Kate Oh, vice president of the Brand Communication Division at LG Home Entertainment Company. “LG OLED remains committed to supporting both artists and audiences who embrace our passion for innovation and positive change. We will continue to empower artists who seek to inspire the world through the intersection of art and technology.
      Visitors to Frieze London 2024 can experience Akomfrah’s artwork Becoming Wind from October 9 to 13 at The Regent’s Park. Visit the
      link hidden, please login to view to step into a world of artistic brilliance and explore captivating collaborations with LG OLED ART. # # #
      * Carbon Trust: Carbon Footprint Reducing certifications (2024 LG OLED evo G4 77”/65”/55”)
      Carbon Footprint Measured certifications (2024 LG OLED evo G4 97”/83”, C4)
      SGS: Environmentally Evaluated certifications (2024 LG OLED evo G4/C4/B4)
