Since updating our OLED65G2PSA to 23.20.56, we experience sprodadic issues with the network where any app requiring network access shows the generic 'no network access' message.
I have found that when this does happen, I can still PING the TV and connect to IP based web pages.  To fix I can either power cycle the TV or I can go into network settings and toggle off/on 'Set automatically' which must just be triggering something in the underlying OS to reload its DNS service.
Setting a static IP makes no difference, setting a static DNS server makes no difference - it is clearly a software issue.  We have had a TV repair company come and replace the boards, which worked right up untill updating to 23.20.56 and beyond.
Has anyone else experienced this, does anyone have a solution ?
  • Popular Now
    • By stevef
      Since my lg-oled65c9pla auto-updated to WebOS 5.5, there is a new bug.
      No software has changed in my amp.  This is an annoying new bug in the TV software, I assume down to some CEC changes.
    • By mesplint
      I have a LG 65QNED92AUA tv that has issues with the Bluetooth connection dropping off when connected to my earbuds. I believe the issue to be software related. LG has sent 2 technicians out to repair and the first technician changed the main board and Bluetooth transmitter which did not resolve the issue.
      There are similar issues with Bluetooth Connection from others.
      Since hardware replacement didn’t help and this is a known software-pattern issue, I would like push LG to specifically address it at the firmware/webOS level. I am unable to escalate to their software team and check if there’s a known patch or beta firmware for the QNED92 line.
      For some reason this line of questioning is not available with in LG customer service.
       Please help!
    • By Matt79
      I've just updated my LG 55UM75 TV to the latest software version - 05..20.15 - and now the picture looks off.
      I've turned off TruMotion, Motion Eye Care, Smooth Gradation, Noise Reduction and Smooth Gradation, but somehow everything still looks artificial.
      Is there another picture setting I'm missing, I've gone through every setting I can find.
    • By Dscottbellamy
      how can I fix lg soundbar model sn6y volume automatically going down after exactly 30 minutes if resetting, unhooking volume down button, drilling vent holes near motherboard, and running a cooling fan did not fix the problem.
    • By bohatier
      TV model: OLED55B13LA
      Example:
