LG have been using 64-bit (aarch64) capable CPUs in their TVs for years.
e.g. Linux LGwebOSTV 5.4.268-320 #1 SMP PREEMPT Mon Jun 17 01:25:25 UTC 2024 aarch64 GNU/Linux
However, the user space shipped with webOS is still only 32-bit!:
getconf LONG_BIT
32
This means that these CPUs are being held back by the continued use of armv7a (32-bit).
There are many benefits for you to switch to aarch64, most notably a performance uplift of 20%+. This benefit would be seen by end users without even a hardware upgrade. Aarch64 has lots of benefits, such as FPU being forced as well as far more registers.
I think its time to ditch armv7a and move future webOS releases to armv8a. Armv8a has been around since 2011!
This change would also increase compatibility as a number of vendors dropped armv7a a long time ago (e.g. Google).
For native app developers they would simply need to recompile their binaries into 64-bit, provide 32-bit and 64-bit binaries during the switch over.
It wouldn't affect any web developers at all, as they interact with the libraries in the same way whether they are 32-bit or 64-bit.
Please consider this move for webOS 26!!!
  • Thanks 1
  • Popular Now
    • By Low Grade
      i always have to turn off the TV using the power switch (put on standby won't do) to view ''live tv'' channels again after watching LG Channels................any way to do that without powering off the tv completely ? 😟
    • By Tv Lg receiver Pioneer
      Hello, I have question about tv LG oled65b13la. This tv is connected to receiver pioneer vsx lx 604 via hdmi arc. When I started tv, receiver switch on too. From any time, this is not funkcionál. I don’t know why. I tried to change some settings, but not working. Do you have any advice about the reason why receiver don’t want to wake up? When I turn tv off, receiver goes to offline too.
    • By Venkata
      Hello Team,
    • By Tony Levy
    • By Splash
      On power switches selected hdmi
