How To Switch Back To ''Live TV'' After Viewing LG Channels
Popular Now
By Deb D
just bought a LG OLED AI B5 4K Smart TV 2025 - but cannot see how to pause live TV - have correct USB  memory plugged in and it records programmes fine but when we try live recording .. Help!   it says the memory is incompatible
By Matt79
I've just updated my LG 55UM75 TV to the latest software version - 05..20.15 - and now the picture looks off.
I've turned off TruMotion, Motion Eye Care, Smooth Gradation, Noise Reduction and Smooth Gradation, but somehow everything still looks artificial.
Is there another picture setting I'm missing, I've gone through every setting I can find.
By Dscottbellamy
how can I fix lg soundbar model sn6y volume automatically going down after exactly 30 minutes if resetting, unhooking volume down button, drilling vent holes near motherboard, and running a cooling fan did not fix the problem.Â
By bohatier
TV model:Â OLED55B13LA
Example:
By hjetschko
Hi, I have a feature request for the sound out setting. I often connect my Bluetooth headphones to the TV. We don't use the internal speaker of the TV, we use the optical sound out setting whenever I don't use Bluetooth. It would make our lives a lot easier if the TV can remember the last sound out setting before connecting to Bluetooth and default back to this setting when the Bluetooth device gets disconnected. At the moment, each time I disconnect the headphones I have to go back into settings and change the sound out setting from internal speaker to optical again.Â
Thanks and regards
Hubert
