LG CLOiD Redefines Home Living by Making Daily Chores Effortless, Giving
Customers More Time for What Matters Most
SEOUL, Dec. 25, 2025 — LG Electronics (LG) will be showcasing its new home robot, LG CLOiD, for the first time at CES® 2026, held in Las Vegas from January 6-9. Representing LG’s continued progress in home robotics, LG CLOiD is designed to perform a wide range of indoor household tasks, enhancing everyday convenience and improving quality of life by making home management more efficient and intuitive.
Positioned as a home assistant, LG CLOiD embodies LG’s vision of the “Zero Labor Home, Makes Quality Time” – a future where technology meaningfully reduces the burden of daily chores, allowing customers to focus more on the people and moments that matter most. The robot marks a significant milestone toward the company’s long-term goal of freeing customers from the time-consuming demands of housework.
Featuring a suitable form factor optimized for today’s living environments, LG CLOiD is built to perform a wide variety of tasks within the home. Its two articulated arms are powered by motors delivering seven degrees of freedom each, providing versatile motion similar to natural movements. Five individually actuated fingers on each hand provide advanced dexterity, allowing CLOiD to perform delicate and precise tasks that require fine motor control.
At the core of LG CLOiD is a chipset integrated into the head, functioning as the robot’s “brain.” This is complemented by a display, speaker, camera and an array of sensors that enable expressive communication, natural voice interaction and intelligent navigation. Powered by LG’s Affectionate Intelligence technology, CLOiD is designed to sense its surroundings, interact in a natural and user-friendly way and refine its responses over time through repeated interactions – aiming to provide more personalized support for everyday tasks.
LG views robotics as a key future growth engine and is accelerating innovation in this strategically important sector. As part of this effort, the company has established HS Robotics Lab within its Home Appliance Solution Company to secure differentiated technologies and further strengthen its core robotics capabilities and product competitiveness. In parallel, LG is actively pursuing joint research initiatives and strategic partnerships with leading robotics companies in Korea and around the globe.
Visitors to CES 2026 can experience LG CLOiD and a variety of real-life “Zero Labor Home” scenarios at LG’s booth (#15004, Las Vegas Convention Center).
  • Popular Now
    • By Interstellarkev
      This is for all that have LG monitors with the latest software that changed UI settings for GAME OPTIMIZER
      I could not find this anywhere on the internet for an update on what happened to the compatibility modes for DisplayPort/HDMI. Everything is outdated.
      Apparently LG updated their UI and MOVED the option for compatibility modes to disable DSC. This USED to be in the common GENERAL tab, but NO LG moved it to the External Devices, which makes no sense as it should be with the common general menu.
      I'm not sure if this is a bug or an oversight, but here it is
      SETTINGS BUTTON > GENERAL > EXTERNAL DEVICES > INPUT COMPATIBILITY
      Why would you disable DSC, you ask?
      Well, if you don't disable this mode, you will not be able to use scaling factors like DSR on NVIDIA. I have seen remarks about AMD being able to use it without this option turned off, but for NVIDIA they are behind on this.
      This WILL disable high frame rates beyond 144 Hz for the trade-off, but you will be able to scale your resolution higher.
      TESTED 1.4dsc off (full dsr support higher res)
    • By Raphael Armin
    • By german_donkey
      I have a TV oled65c5elb with webos25 10.2.1-5504.
      I programmed in Home assistant a few Dashboard to contol the TV. I can Switch the Channels from live TV by Home Assistant. But Not in LG Channels or other Apps Like Pluto TV.  If someone can Help me, please Post it. Thank you.
    • By Mimiu
      As the title says, please fix ASAP playback of Profile 7 (FEL/MEL) inside Matroska (.mkv) container.
      On WEB OS 24 it was working with backwards compatibility to HDR10 base layer - in other words the Dolby Vision was omitted.
      Currently in WEBOS 25 the files won't work/play.
      As LG started to support Profile 8 Dolby Vision from WEB OS 25 in MKV properly, this should be easy fix for LG.
      Example of MediaInfo of Profile 7:
      Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main [email protected]@High HDR format : Dolby Vision, Version 1.0, Profile 7.6, dvhe.07.06, BL+EL+RPU, no metadata compression, Blu-ray compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible Codec ID : V_MPEGH/ISO/HEVC Duration : 1 h 25 min Bit rate : 55.3 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.278 Stream size : 32.9 GiB (91%) Language : English Default : Yes Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : BT.2020 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 966 cd/m2 Maximum Frame-Average Light Level : 223 cd/m2 Cheers and thank you.
      CES Best of Innovation Award Winner Redefines
      In-Vehicle Experience Powered by Affectionate Intelligence
      SEOUL, Dec. 17, 2025 — LG Electronics (LG) will unveil an immersive experiential space at CES 2026 that brings the company’s future mobility vision to life through Affectionate Intelligence. The exhibit invites visitors to experience firsthand how AI can reshape the driver, front-passenger and rear seating areas, reimagining the whole cabin as a more intuitive and human-centered space designed to enhance every ride.
      This new series of solutions has earned the CES 2026 Best of Innovation Award in In-Vehicle Entertainment, marking the first time the LG Vehicle Solution Company has won the category’s top honor. The system brings together cutting-edge display technology, advanced in-cabin sensing, and on-device AI under a comprehensive AI-Defined Vehicle architecture.
      The showcase features three core experiential solutions: the Mobility Display Solution, which transforms the windshield into an intelligent interface; the Automotive Vision Solution, which enhances safety and delivers context-aware information to the driver and front passenger via Vision AI; and the In-Vehicle Entertainment Solution, which provides personalized content recommendations, memory-based media and real-time translation.
      In the Mobility Display Solution zone, visitors can experience how AI intuitively presents essential information through a transparent OLED-equipped windshield. For example, when approaching a traffic signal, AI displays the remaining wait time above the signal, selectively providing only the most relevant information at that moment. In autonomous driving mode, the system analyzes the surrounding environment and generates corresponding visual scenes: cherry blossom petals flutter across the display on tree-lined roads, while a monotonous tunnel transforms into an enchanting forest, creating an immersive, near-virtual-reality experience.
      The Automotive Vision Solution is an advanced in-cabin sensing solution powered by LG’s Automotive Vision System, designed to enhance safety while enabling context-aware, empathetic interactions and personalized content delivery. The solution tracks driver movement, gaze direction, attention, clothing color and gestures in real time, allowing the system to understand and respond to the occupant’s state. Through eye tracking and gesture control, the system expands the range of interest-based information, while anamorphic display graphics heighten immersion and realism. For instance, in autonomous driving mode, if a front-seat passenger looks at an advertisement displayed on a building, gaze recognition can trigger related information on the passenger display, providing seamless product discovery and purchasing.
      The In-Vehicle Entertainment Solution delivers personalized entertainment and interactive communication. By recognizing scenery outside the vehicle, AI can display photos linked to past memories associated with that location on the window display. Passengers can share these moments in real time through video calls with family members. During long journeys, AI recommends content tailored to individual tastes, providing entertainment that turns miles into moments. In another scenario, if a restaurant staff member communicates using sign language, AI interprets the gestures into on-screen text to support smooth, two-way communication.
      “We are bringing our future mobility vision to life by embedding AI across our solutions – many of which, including in-cabin sensing, are already in production with global OEMs,” said Eun Seok-hyun, president of the LG Vehicle Solution Company. “By accelerating these innovations to market, we aim to pioneer the era of AI-driven vehicles in the years ahead.”
      LG AI-Powered In-Vehicle Solutions will be on display at the company’s booth during CES 2026 from January 6-9 (#15004, Las Vegas Convention Center).
