Help with enlarging subtitles
Where are the subtitles coming from?
TV channels or downloaded video on disk?
The latter are quite easy to adjust
Start the video in the Media Player
Click then Scroll down with the centre button on your remote
You will see a SUB button come up on the screen
Click on it, and in the menu on the right adjust the Size, at the bottom of the list
  • Popular Now
    • By ALIENQuake
      If I play an MKV video from a USB drive that contains multiple subtitle tracks with correct language tags, will webOS automatically select the appropriate subtitles, for example based on the TV interface language or the country where the TV is being used? Or it will just select first one/makred as fefault?
    • By ZealousFlamingo
      So basically I just got a new LG OLED TV (55 inch C5) and my Dad's C4 was seemingly able to display internal or embedded subtitles in TV shows through the built-in media player from external USB storage just fine with some tinkering in the menus.
      But with mine, the subtitles are displaying all of the raw text in the subtitle files in the player, not using the arguments properly at all.
      Pictures included for reference
      Is there any way to fix this other than literally doing subtitles for every episode externally, in a seperate file?
      These subtitles work fine when I play from the exact same storage device on my phone through VLC, and again on my Dad's LG TV
    • By Simon1973
      I recently bought a 50NANO90A6B TV and so far I have to say it's a fantastic upgrade from my old Sony 40".
      However, I've one small niggle problem (only had the TV since Sunday)... The YouTube app doesn't seem to want to work! it shows the logo with a spinny circle, then the logo starts again with the spinny circle... this just repeats over and over.
      All other apps (iPlayer, Jellyfin, Plex, ITV, CH4 etc...) work as does the LGTV app, so the WiFi connection is fine!
      I've uninstalled and reinstalled the YouTube app a few times, but it does the same each time!
      Anyone know how I can sort this? any other suggestions for fixing it!
      I'm currently using my Chromecast with GoogleTV for YouTube at the moment.
      I'm in the UK by the way! And the TV is set to that, in all the relevant settings locations.
    • By MURAD
    • By Ricasan
      Hello there!
      Recently the prime video app started to require the update to open, and now i am having a problem, because this app update REQUIRES to a system update of firmware (to webos24),
      but it will make impossible to homebrew later.
      So, can someone at least provide the last or update ipk of amazon (amazon.ipk), so i can install manually?
      Thanks!
