Subtitles for a particular Hulu show is sometimes off screen
Popular Now
By ALIENQuake
If I play an MKV video from a USB drive that contains multiple subtitle tracks with correct language tags, will webOS automatically select the appropriate subtitles, for example based on the TV interface language or the country where the TV is being used? Or it will just select first one/makred as fefault?
By ZealousFlamingo
So basically I just got a new LG OLED TV (55 inch C5) and my Dad's C4 was seemingly able to display internal or embedded subtitles in TV shows through the built-in media player from external USB storage just fine with some tinkering in the menus.
But with mine, the subtitles are displaying all of the raw text in the subtitle files in the player, not using the arguments properly at all.
Pictures included for reference
Is there any way to fix this other than literally doing subtitles for every episode externally, in a seperate file?
These subtitles work fine when I play from the exact same storage device on my phone through VLC, and again on my Dad's LG TV
By chris7ben
The sound and picture are out of sync when screen mirroring from my iPhone 16 Pro to my LGQNED70A6A TV, using the internal speaker. I have tried all the recommended tips in the settings to cure the issue with no success. However, when I isolate the TV from the mains supply for 60 seconds and restart it, the syncing issue is cured but degrades after a day or so. My iPhone software is up to date and there is no firmware upgrade available for the TV. My LinkSys router has a full fibre connection. The only connection into the TV is the mains supply. Any help much appreciated. Thanks in advance.
By MURAD
subtitle issue
I am watching"Kollective" on Hulu and some of the subtitles are cut off on the lower left side of the screen.
