Sound and picture out of sync when screen mirroring from my iPhone to my LGQNED70A6A TV
The sound and picture are out of sync when screen mirroring from my iPhone 16 Pro to my LGQNED70A6A TV, using the internal speaker. I have tried all the recommended tips in the settings to cure the issue with no success. However, when I isolate the TV from the mains supply for 60 seconds and restart it, the syncing issue is cured but degrades after a day or so. My iPhone software is up to date and there is no firmware upgrade available for the TV. My LinkSys router has a full fibre connection. The only connection into the TV is the mains supply. Any help much appreciated. Thanks in advance.
  • Popular Now
    • By Stylianos
      i am having an issue with my LG OLED77C2 tv that started happening (i believe) once i have updated from web24 to 25. It seems like whenever the tv is displaying a source from any of my four HDMI inputs, while i am watching the screen goes black randomly for a few seconds and it loses audio as well during the black screen. Once this happens the audio usually comes back as soon as the image does, however not always. The audio might dissapear completely. In order to fix that i might need to power cycle the tv or unplug the hdmi input out, wait a little and then plug back in. Moreover, sometimes when the black screen flash happens it cripples most of my native apps on the tv. So if i switch to netflix or youtube right after the black screen flash, both apps populate normally all the video/film options in the main menu but when i try to actually play any of the video/films, they dont play and it is throwing an error. These black flashes never happen when i am watching netflix or youtube. Only when using my hdmi inputs. ive changed brand new high quality cables but that did not fix my issue. For the xbox i was already suing an ultra hish speed 2.1 hdmi cable but ive re placed that as well with a brand new one. ive also changed the tvs main board to a brand new and it still happening. Once the dealer changed the board, the tv was behaving normally without the issue. However after a few days i updated the tv to the latest firmware and this started happening. what do i do?
      FYI: I tried EVERY SINGLE option to troubleshoot the issue. Disabled VRR, AMD Freesync, ALLM, HDMI Deep Colour, SIMPLINK, I basically set my tv to display video and audio in the most archaic way just to troubleshoot. Still doing it. I am using an xbox series x on input 1 and a mag520 box on input 3. Does it on both sources. Moreover, in case this helps whenever this happens while on the xbox the Dolby vision/HDR logo appears on the top right right after the video comes back once the black screen is over depending on what settings i have the xbox on. Also swapped to different inputs. Still doing it
    • By rems1989
      Hi everyone,
      I’m running into a very inconsistent issue when streaming my Windows 11 PC with apollo (fork of Sunshine) to my LG C4 TV using Moonlight (webOS).
      The setup worked perfectly for about 6 months at 2K / 90 FPS with high bitrate.
      Around 2–3 weeks ago, the issue started without any clear change on the PC side (possibly after a webOS update).
      Symptoms:
      •    Moonlight on the TV shows “connection unstable” with a black screen
      •    Behavior is inconsistent and unpredictable :
      Sometimes nothing works at all with black screen Sometimes 2K / high bitrate work or not yesterday 2K didn't work but lowest resolution (1280x..) worked •    Streaming to my phone works fine, so the host PC and network seem OK
      What I’ve tried:
      •    Clean reinstall of Moonlight on the TV and Apollo/Sunshine on the PC
      •    H.264 only (no HEVC, no AV1, HDR off for testing)
      •    All bitrate / FPS / resolution combinations
      •    Ethernet and Wi-Fi
      •    Different Windows display modes
      •    Virtual display disabled
      Setup:
      •    Host PC: Windows 11, NVIDIA GPU (RTX 3070)
      •    Apollo installed on PC
      •    LG C4 TV, webOS 10.2.2, sideloaded Moonlight client (1.6.36)
      •    PC and TV tested on both Ethernet and Wi-Fi (2 gbps internet speed on my computer)
      •    Streaming to other clients (android phone) seems to work reliably
      Feel free to ask me any information needed
      Thanks for your help
    • By hjetschko
      Hi, I have a feature request for the sound out setting. I often connect my Bluetooth headphones to the TV. We don't use the internal speaker of the TV, we use the optical sound out setting whenever I don't use Bluetooth. It would make our lives a lot easier if the TV can remember the last sound out setting before connecting to Bluetooth and default back to this setting when the Bluetooth device gets disconnected. At the moment, each time I disconnect the headphones I have to go back into settings and change the sound out setting from internal speaker to optical again.
      Thanks and regards
      Hubert
    • By John Peet
      TV is a week old and the internal speaker has stopped working when in HDMI ARC + internal speaker sound output mode. The internal speaker itself works fine when in “internal speaker” sound output mode. I’ve checked all the settings that I can and can’t find anything that would correct this issue.
    • By bos2prov
      I have a Roku device attached to my LG TV model # 55UQ7570PUJ. As I’m watching something on the Roku and using my Roku remote, every now and then something that I press on that Roku remote brings up the LG ‘Select a menu item’ screenwhere AV Reset is highlighted. Any idea what could be happening here? One clue: after I press the undo button on the LG remote to get rid of that window, I find that the volume is all the way down. Maybe I’m hitting the Roku remote’s Mute button in some weird way and that brings up the ‘Select a menu item’ window?
      It’s surprising that something I press on the Roku remote brings up an LG dialog, but that’s what’s happening. Thanks for any help.
