LG 55 NANO 816NA HDMI ARC
Popular Now
By starwoodtech
By jikhead
I'm not getting any audio from the apps via the HDMI via ARC connection to my receiver. This occurred two weeks ago and was unable to resolve it, but ironically there was new firmware released that same day for my B6 (3/31/17) and this fixed the issue. However, now I again can't get it working after a TV reset and tinkering with the audio settings again. I tried to load the firmware again, but it appears this is not possible to forceable load the same firmware.
By bohatier
TV model: OLED55B13LA
Example:
By Stylianos
i am having an issue with my LG OLED77C2 tv that started happening (i believe) once i have updated from web24 to 25. It seems like whenever the tv is displaying a source from any of my four HDMI inputs, while i am watching the screen goes black randomly for a few seconds and it loses audio as well during the black screen. Once this happens the audio usually comes back as soon as the image does, however not always. The audio might dissapear completely. In order to fix that i might need to power cycle the tv or unplug the hdmi input out, wait a little and then plug back in. Moreover, sometimes when the black screen flash happens it cripples most of my native apps on the tv. So if i switch to netflix or youtube right after the black screen flash, both apps populate normally all the video/film options in the main menu but when i try to actually play any of the video/films, they dont play and it is throwing an error. These black flashes never happen when i am watching netflix or youtube. Only when using my hdmi inputs. ive changed brand new high quality cables but that did not fix my issue. For the xbox i was already suing an ultra hish speed 2.1 hdmi cable but ive re placed that as well with a brand new one. ive also changed the tvs main board to a brand new and it still happening. Once the dealer changed the board, the tv was behaving normally without the issue. However after a few days i updated the tv to the latest firmware and this started happening. what do i do?
FYI: I tried EVERY SINGLE option to troubleshoot the issue. Disabled VRR, AMD Freesync, ALLM, HDMI Deep Colour, SIMPLINK, I basically set my tv to display video and audio in the most archaic way just to troubleshoot. Still doing it. I am using an xbox series x on input 1 and a mag520 box on input 3. Does it on both sources. Moreover, in case this helps whenever this happens while on the xbox the Dolby vision/HDR logo appears on the top right right after the video comes back once the black screen is over depending on what settings i have the xbox on. Also swapped to different inputs. Still doing it
By John Peet
TV is a week old and the internal speaker has stopped working when in HDMI ARC + internal speaker sound output mode. The internal speaker itself works fine when in “internal speaker” sound output mode. I’ve checked all the settings that I can and can’t find anything that would correct this issue.
