Freesat on QNED80T6A
I have a 55 QNED80T6A that has a satellite cable connection on it. I've connected my satellite cable to it but I dont get anything. How do I set it up?
  • Popular Now
    • By ColinMawbey
      TLC on Freesat ....Channels 144 & 150 have become scrambled... screen shows No  CI MODULE...as far as i know this OLED 65C4 tv does not have the Module fitted..tried a reset, & checked cable connections all good,,, both channels work fine on freeview, any help out there....
    • By mix-e
      Yes! Freesat does work on the LGE TV that I have 2021 model. Using a SKY DISH and LNB in the UK. Okay now that sorted out.
      With WEBOS 3.34.95
      Then you launch the guide on freesat the preview window does not display a picture. Just says downloading" If you then select a channel from the guide the TV picture is shown.
      Looks like a bug to me...
      Also on the channel info screen. The displayed info screen box is very big and the font size is very very small even on a quite large TV.
      It would be better is a bigger font could be displayed.
    • By Room13
      Hi,  I have a 55 C9- on the 4.80.03 firmware- I love it but one aspect is driving me crazy- the Programme Manager- Edit Favourites with the UK's Freeview via antenna and Freesat. I like to arrange my channels in a certain order as favourites both on my TVs and my hacked Windows MCE. BUT after I have done this, about 6-12 channels have jumped out of order by the next morning. Also, when I then try to move a channel favourite, some of them are very stubborn and won't move- keeping their original position- forcing me to clear the favourites and start again. Not sharing a favourites name seems to have helped with the Freesat favourites not jumping around. But even switching off Programme List Update has not done any good with Freeview which has still changed. In fact having Programme List Update switched on caused a pop up- asking me about auto tuning new channels- even though I had the Smart Retuning option turned on, when I went to my saved Freesat favourite list it had been wiped clean. As I say- frustrating! I don't want to reorder channels- and Freesat won't let you anyway- I just want to be able to reorder favourites- and for them to not move! Thanks in advance
    • By Ian Richardson
      OK, I have had this TV for about a week and I still haven't found how to change from Freesat to Freeview!
      The remote does NOT have an input button to easily select what LG choose to call Antenna and Sat so how can you easily swap between Freesat and Freeview?
      My old Panasonic Plasma was really easy, why have LG made it impossible?
       Ian
    • By Jimbo
      Does anyone else have issues with Freesat signal break up, I have taken the feed from my old Freesat box, but it only is able to show or tune about 60 % of the channels the standalone Freesat box was
      smaller.mp4
