TLC Freesat Channels 144 & 150 have become scrambled...
Popular Now
By Interstellarkev
This is for all that have LG monitors with the latest software that changed UI settings for GAME OPTIMIZER
I could not find this anywhere on the internet for an update on what happened to the compatibility modes for DisplayPort/HDMI. Everything is outdated.
Apparently LG updated their UI and MOVED the option for compatibility modes to disable DSC. This USED to be in the common GENERAL tab, but NO LG moved it to the External Devices, which makes no sense as it should be with the common general menu.
I'm not sure if this is a bug or an oversight, but here it is
SETTINGS BUTTON > GENERAL > EXTERNAL DEVICES > INPUT COMPATIBILITY
Why would you disable DSC, you ask?
Well, if you don't disable this mode, you will not be able to use scaling factors like DSR on NVIDIA. I have seen remarks about AMD being able to use it without this option turned off, but for NVIDIA they are behind on this.
This WILL disable high frame rates beyond 144 Hz for the trade-off, but you will be able to scale your resolution higher.
TESTED 1.4dsc off (full dsr support higher res)
By Charley
On my LG 'smart' TV now for some reason I can now only watch the LG channels but not the fiber-optic programming on wi-fi . The HDMI 1 feed I normally use shows 'dark' on the Dashboard even though I can get the green checkmark on it. How do I reconnect it? The Dashboard shows my feed as ethernet/cable; which is wrong but efforts to correct it have failed so far.
Chemicals Industry -
By andystaffs
It seems our LG TV has done an update which has removed the "standard " BBC channels from the guide . After one day BBC2 has reappeared . The HD channels are present though . I've done a re-scan but no change . I've looked to see if we can move BBC1 HD (on 101) to Chanel 1 on the guide but doesn't seem to be an option.
Anybody else have this problem and any cures ?
By Low Grade
i always have to turn off the TV using the power switch (put on standby won't do) to view ''live tv'' channels again after watching LG Channels................any way to do that without powering off the tv completely ? 😟
ColinMawbey
TLC on Freesat ....Channels 144 & 150 have become scrambled... screen shows No CI MODULE...as far as i know this OLED 65C4 tv does not have the Module fitted..tried a reset, & checked cable connections all good,,, both channels work fine on freeview, any help out there....
