My LG TV : Model 75UM7000PLA
The Problem:
When I want to use my wireless optical headphones, I switch the TV “Sound Out” option to “Optical” or “Internal TV Speaker + Optical.” But when I do this, the TV sends a command to the Yamaha receiver that forces it to switch its input to Optical. This stops playback of my HDMI device connected to the Yamaha because the Yamaha input is changed.
What I would like:
Can LG update the TV firmware so that:
1️⃣ When I select “Optical” or “Internal TV Speaker + Optical” in “Sound Out,” it does not cause the Yamaha receiver to switch its input source?
OR
2️⃣ Add a new “Sound Out” option that sends audio to Optical without sending a command to change the Yamaha input?
OR
3️⃣ Make the existing “Internal TV Speaker” mode also output audio through Optical, but without causing the Yamaha input to switch?
Note:
Disabling ARC is not a good solution because:
Audio from devices connected to the Yamaha receiver still plays on both TV and Yamaha speakers.
Audio from devices connected to the TV no longer plays on the Yamaha speakers.
Thank you!
  • 2 weeks later...
I feel your pain, jmk. My 27" LG "kitchen TV" (I'd have to look up the model) has the worst built-in speakers. Sounds like a 1960's transistor radio, very tinny and brash.
It does not have a 3.5 earplug out socket, so I have to buy an adapter to convert optical sound out to 3.5 analog.
An extra 2 or 3 steps every time I turn the TV on, to connect my Phillips external speakers (great speakers, BTW).
What were they thinking? A current high dollar smart TV without a 3.5 mm earplug out capability?
Otherwise, I'm pleased with the excellent true HD picture and smart 5G connectivity.
Such a simple and universal thing... a 3.5mm earplug out socket, with volume control.
Missing on a $400 LG premium quality TV (with less than $100 Visio sound quality, as delivered).
  • Popular Now
    • By Cody94549
    • By Farhad Radka
      Hi all, hoping for some expert help.
      TV: LG 65QNED86T6A.ADKFLJD (Russia-market unit, now in Iran), S/W 33.31.68.01 (webOS25), 2024 build.
      Location settings only show CIS/Russian-speaking countries.
      Using an original Factory SVC Remocon (WK-17226), both IN START and ADJ (code 0413) lead to the same SVC menu.
      Current Area Option values: Area Code 3638 / Continent Index 54 / Language&Country CS / HW Settings EU.
      I've tried entering various Area Option codes (adjacent blocks 3712/3840/3968, and legacy ME/CIS codes from older webOS threads) — all rejected with an error. Continent Index / Language&Country / HW Settings appear to be read-only/derived fields, not directly editable.
      Has anyone successfully changed the Area Option on a 2024-model webOS25 QNED TV? Any known working codes or is this generation's SVC menu fully locked without RTOOL/GSDF access?
    • By akacabo
      I am trying to change my tv region from middle East to USA but changing won't take effect
      What should I do here that I am missing
    • By chris7ben
      The sound and picture are out of sync when screen mirroring from my iPhone 16 Pro to my LGQNED70A6A TV, using the internal speaker. I have tried all the recommended tips in the settings to cure the issue with no success. However, when I isolate the TV from the mains supply for 60 seconds and restart it, the syncing issue is cured but degrades after a day or so. My iPhone software is up to date and there is no firmware upgrade available for the TV. My LinkSys router has a full fibre connection. The only connection into the TV is the mains supply. Any help much appreciated. Thanks in advance.
    • By Arthur
      It would be nice to have an ability to play video (not only?) content from folder in shuffle mode.
      Thanks.
