I am trying to change my tv region from middle East to USA but changing won't take effect
What should I do here that I am missing
  • Popular Now
    • By Farhad Radka
      Hi all, hoping for some expert help.
      TV: LG 65QNED86T6A.ADKFLJD (Russia-market unit, now in Iran), S/W 33.31.68.01 (webOS25), 2024 build.
      Location settings only show CIS/Russian-speaking countries.
      Using an original Factory SVC Remocon (WK-17226), both IN START and ADJ (code 0413) lead to the same SVC menu.
      Current Area Option values: Area Code 3638 / Continent Index 54 / Language&Country CS / HW Settings EU.
      I've tried entering various Area Option codes (adjacent blocks 3712/3840/3968, and legacy ME/CIS codes from older webOS threads) — all rejected with an error. Continent Index / Language&Country / HW Settings appear to be read-only/derived fields, not directly editable.
      Has anyone successfully changed the Area Option on a 2024-model webOS25 QNED TV? Any known working codes or is this generation's SVC menu fully locked without RTOOL/GSDF access?
    • By tazcox
      hello
      i have buy a 55UB850V , i'm really happy for the quality but during a tv show i can't change the audio language ..
      on my la 690 i can choose the audio language with the menu Q-menu ..
      i can't find this menu on the UB...
      anyone could help me ?
    • By Raus
      Hello, I know that other LG WebOS users have the same problem as me, but I can't find a solution on the web.
      Perhaps one of you experts can help me.
      Shortly: manually sort the app icons on my LG Smart TV (OLED77C55LA) and place the “TV Channels” icon in the first position (on the left, to be clear). Before all the others (e.g. Netflix, PlutoTV, Prime, etc.), but when I turn off the TV for a few hours and turn it back on, I find the “TV Channels” icon in last position.
      I have tried putting it in second position, third position and so on, but every time I turn it back on, I find it in last position.
      Can anyone help me?
      Thank you.
    • By Hemant_5400z
      Hi All,
      I have an LG Oled65C554, I know I I can rearrange the apps screen. What I cannot seem to figure out is how to arrange/re-arrange the smart hub lay.
      On the left I have the Input and a scroll, however on the right side I have a BIG part that takes LG smart divices en IOT-devices which is empty as I don't have ohte LG appliances.
      I woul like to get rid of the right part on the screen or even better add my hoemkit devices to the dashboard(not sure if that will be possible).
      Anyone who got this working?
    • By NO UHD
      So i have a brand new OLED 65inch, the Sky now APP installed on the tv wont play the UHD content from sky, I do have the right subscription and when i use a amazon fire stick with the Now app installed it will play UHD Content, i just cant figure out why the tv installed app wont play it.  The Tv will play UDH content from other apps installed on the TV so i know its capable just something between the TV and Now app wont allow UHD Content, any ideas???
