By OliverRC
By Aventiled
Hey
I have an OLED C3 evo
A Pioneer amplifier is connected to the optical output.
I want to connect Bluetooth headphones and use them at the same time as the amplifier.
The thing is, I haven't seen such an option on TV. It is possible to play simultaneously with the Bluetooth headphones and the internal speakers on the TV.
There is no option for Bluetooth and the optical port at the same time.
Am I missing something here?
Dani
By Danilo Peixoto Ferreira
I wish I could control the volume of my LG TV 65NANO96SNA (webOS 4.50.71) using Apple TV 4K 3rd Generation (tvOS 17.3) with HDMI CEC (Belkin AV10176bt2M-BLK cable). The Apple TV has it on Settings, however, the TV does not respond to it. Turn on/off works. Volume control only works with IR. Could we prepare an update to support and fix it?
- 2,754 views
- 1,743 views
- 51 answers
- 100,493 views
- 4 answers
- 6,790 views
Leo Gsx
There is a thread about the issue. Please use it instead.
TL;DR unplugging and plugging the HDMI cable back to the TV fixes the problem until the TV is turned off. Next time the TV is on I have to repeat this.
I have the following setup:
It used to work OK but one day it stopped reproducing sound from the soundbar. When I try to adjust the volume I just have a grey DISABLED icon.
So far, I have tried to play with all kind of options from the menu of the TV and I have power cycled it, factory reset the TV as well. I have tested the soundbar and the cable with my other LG TV and it works perfectly. I am assuming it is a hardware problem with the port, but I just wanted to ask here for any advice?
Today unplugged and replugged the cable (again). The issue was gone. Could be some SW update on the Soundbar as I had a BT sync issues which are now gone.
Link to comment
Share on other sites
