LG TV feature requests
1-disable floating pointer
2- name hard drives
3-be able to delete empty folders, not just video files
4-make pixel refresh automatically on cumulative hours
5-pixel refresh page confusing needs redescribing.
6-allow more padding time for recordings, up to 1 hr user defined
7-allow custom recordings to be given a name to help remember what they are
8-allow saving of TV settings to a file on a usb pen or HDD.....several named files would be good, then family could chose their favourite settings and load the file from a usb pen / hard drive. Plus could have settings that are in test, in case doesn’t work out
9+a text file to describe firmware update content is
10- would like a feature request section on LG website for ideas and allow voting, you would then have an easy access to ideas & their popularity
11-Allow setting of recordings manual or through E.P.G. To have ALL options available I.e. Pad time recurring recoding etc. Without having to exit and go back to Edit mode to change the other settings.
  • Popular Now
    • By Cody94549
    • By Ramesh Chand Vishwakarma
      Regards,
      MD/CEO
      Noida, UP
      +91 9910246766
    • By Raphael Armin
    • By stevef
      Since my lg-oled65c9pla auto-updated to WebOS 5.5, there is a new bug.
      No software has changed in my amp.  This is an annoying new bug in the TV software, I assume down to some CEC changes.
    • By FUNTIK
