add 10bit sdr and hevc supports to webos and youtube support.
Popular Now
By Uuganbayar
there is no youtube app in TV home. even in apps store there is no youtube. TV model 65NU900B6LA
By Ramesh Chand Vishwakarma
Regards,
MD/CEO
Noida, UP
+91 9910246766
By Raphael Armin
By stevef
Since my lg-oled65c9pla auto-updated to WebOS 5.5, there is a new bug.
No software has changed in my amp. This is an annoying new bug in the TV software, I assume down to some CEC changes.
By FUNTIK
