  • 3
Enabling usb recording and live tv
Hblone
Hallo, I bought a 55un74006LB smart tv in Italy. It seems not to have usb recording capabilities, according to the information on the italian website, but the UK site declare it has. I think it's the same product with the same functions, so how can I turn the live tv and usb recording on? I think I found the options in the service menu but I cannot change the values. Any suggestion?
Link to comment
Share on other sites
Hello to all members enjoying this topic:
@Hblone I have a question for you.
I'm gonna buy an LG tv in Italy and the PVR is locked too. Reading your comments, I understood that, at the end, is possible to enable the PVR/DVR function here too.
Which is the part of toolopt6 country code to identify Italy ? the 1st two,three,four... digits? What about the rest of digits? Do I have to insert randomly?
Did you figure out any problem after have changed that parameter? is everything working fine?
Thanks in advance for your time,
Filippo
Link to comment
@filfae Yes, I finally managed to enable PVR and Live TV functions and everything is working fine!
I don't know the meaning of the Energy/Country Code at Toolopt6, what I could understand is that changing them will enable/disable various options in the TV software - I believe they refer to the different TV models and to the Countries in which they are sold. I also think that different TV models have different toolopt6 "class" codes, meaning the first two or three digits in the code.
What I suggest you to do is to take a screenshot of the default code on your TV, then search for a screenshot (you can probably find it online or asking on this forum) in which the code has the same first 3 digits but the "DVR Ready" switch set to ON and, VERY IMPORTANT, all the other options set the same as your TV. Selecting a code with random options settings could result in malfunction or damage to your TV: I was lucky because the first time, even if I typed in a wrong code for my TV and it deleted the Magic Remote support engine and some other minor functions, as I later typed in a correct code of the right class of my TV, a software update was released that fixed the problem, and everything works great since then.
When you find and type in the correct toolopt6 code for your tv, then you must change the geographic area in the options menu to a country in which DVR is enabled, and the channel list is the same as Italy. I selected Estonia and it works great. The only issue is that I had to turn off automatic time zone selection, so twice a year I have to correct the time manually.
Hope it will help you.
Link to comment
Still on this question:
I am looking for a "ToolOPT6_Energy/Country" code with enabled PVR/TS for my OLED42C26LB.
Here what I have there:
Some of you may be interested to "ToolOPT6_Energy/Country" code of my OLED65C11LB:
It is a non Italian model. I could enable PVR/TS by changing broadcasting position to Austria and getting back to Italian LCN. Here the procedure I have used:
In case you are interest you are interested, you have only to translate and change ITA with your country. It is generic and it should work.
Link to comment
I have got from a friend the code for his OLED42C21LA:
I have tried to update the code on my one, but I cannot select it for modification (on my C1 I can).
I have FW 03.30.16. Is that common to C2? If somebody can test, it would be helpful.
Any idea I can enable SM/ToolOPT6_Energy/country for modification?
Link to comment
5 hours ago, Paolo Sala said:
Hello everyone,
Same problem here with an LG Nanocell(43NANO78):
Any code available for Italy?
Thank you,
Before wasting time finding a foreign TV (with the same hw) with that feature enabled, have you checked if the field can be modified? On my C1 it is possible, but on my C2 it isn't.
Link to comment
In facts it seems locked.but it's strange maybe an unlock procedure exists... Btw the same television sold in Romania has all the features including time machine and PVR with the same hw 😤
Link to comment
Ya, My C1 is imported from Croazia. So I have not even to look for a code (anyhow risky).
I could get the code for my C2, but no way. I have posted for suggestions about how changing that field, but I could not get any feedback
Link to comment
On 10/17/2020 at 8:52 PM, T0BlAS said:
I have the same Problem with the LG UN7300 from italy. The reason for this is, that LG doesn't pay the italian tax for recording devices (SIAE), which also includes TV with DVR/PVR.
I went in the EZ-ADJUST menu and found the DVR Ready function under "ToolOPT6_Energy/Country".
It's greyed out so it's not possible to turn it on.
Would it be possible to change the number of "ToolOPT6_Energy/Country" to a number for a country where USB Recording is available? Is someone here with an LG UN7300 and working Recording who can share this number?
how can go to EZ-Adjust menu in lg oled 65c15
Link to comment
    • By blshambles
      When will the 4.0 update be available for my 2016-17 LG Smart TV?  I just got Alexa and can't use it for the TV unless it has the 4.0 version.  Model #70UH6350-UB.
      HiEV Charger, an LG Affiliated Company, Has Unveiled Its
      New Portfolio of Convenient and Reliable Electric Vehicle Chargers
      SEOUL, May 25, 2023 — LG Electronics (LG) is expanding its electric vehicle (EV) charger solutions business, a move expected to further solidify the company’s position in the fast-growing EV charger segment. LG held a ceremony yesterday to celebrate the commencement of EV charger products manufactured by HiEV Charger (formerly known as AppleMango). HiEV Charger, an EV charging solution company, was acquired by LG, GS Energy and GS Neotek in 2022.
      HiEV Charger unveiled its product portfolio during the ceremony, which features four different chargers: two 7kW models (wall-mounted and stand-type) and two fast-charging models (100kW and 200kW). All of the new products offer convenient installation and are suitable for use in multiple environments, such as homes, office buildings and a diverse range of other commercial facilities.
      The newly introduced EV chargers boast an array of safety-enhancing features. In addition to being water- and dust-resistant, the chargers are equipped with functions designed to provide electrical and thermal protection throughout the charging process. The new chargers also have a slim depth that supports the efficient use of space, while the inclusion of two connectors means two EVs can be charged simultaneously. Simple management is provided through features like connector lock detection and remote updates.
      By combining its know-how and technical prowess from the B2C and B2B sectors, LG is able to deliver differentiated solutions and enhanced customer experiences. The company’s well-established capabilities in manufacturing, quality control, after-sales service and supply chain management create the foundation necessary to achieve sustained success in the EV charging solution business. Looking beyond the domestic market, LG is currently planning EV charging product launches and related collaborations in countries around the world.
      The global EV charging market is expected to grow to USD 186 billion by 2030, according to Roland Berger, a global management consulting firm. The market expansion is being driven by several factors, including the ongoing implementation of regulations aimed at protecting the environment, and the continuous progress of vehicle electrification.
      “The start of EV charger production marks a significant milestone for LG, propelling us on a journey to becoming a total EV charging solutions provider,” said Suh Heung-kyu, vice president and head of the Electric Vehicle Charging business division of LG Electronics Business Solutions Company. “We will focus on delivering convenient and fast EV charging solutions for EV owners and differentiated EV charging solutions offering diverse form factors and new services for our valued partners.”
      Reflecting Company’s Objective to Realize a Better Life for All, Proprietary Glass
      Materials Offer Hygiene Benefits and Can Help Restore Marine Ecosystems
      SEOUL, May 23, 2023 — LG Electronics (LG) is bolstering its advanced materials business by utilizing an in-house developed antimicrobial glass powder and marine glass.1 LG’s antimicrobial glass powder offers excellent hygiene benefits and possesses glass’s characteristic chemical and thermal stability, durability and resistance to discoloration. Demonstrating the company’s commitment to good ESG management, LG’s marine glass can play an important role in helping to restore marine ecosystems. Both products are expected to secure growth opportunities for LG’s new advanced materials business.2
      LG has been using its antimicrobial glass powder in several different home appliance lineups, including refrigerators, washing machines and air conditioners, since 2022. Helping to make product usage more hygienic, the company’s antimicrobial glass powder is employed in the manufacturing of plastic parts – such as fridge and dishwasher handles – that come into frequent contact with human skin.
      The antimicrobial glass powder leverages LG’s expertise in glass composition design technology and in-depth understanding of the home appliance usage environment. LG’s glass powder offers anti-fungal and antibacterial properties when combined with various materials, such as plastics, fibers, paints and laminates, and is predicted to accelerate the expansion of the company’s advanced materials business.
      Additionally, LG’s marine glass is based on the company’s own precise release technology for glass material. When dissolved in water, the marine glass transforms into inorganic ions, which contribute to the restoration of the marine ecosystem by fostering the growth of microalgae and algae in the ocean.
      Furthermore, LG’s marine glass is an excellent alternative to the red clay used to help mitigate the ecological damage done by red tides, where harmful algal blooms cause the surface of the ocean to turn red. And because the glass material dissolves in water, it prevents secondary contamination of the marine environment.
      With its antimicrobial glass powder serving as the starting point, LG’s advanced materials business is embracing a novel concept aligned more closely with the company’s Better Life for All ESG vision. The business plans to expand its operations to include marine ecosystem restoration, with a view to safeguarding the Earth’s oceans and waterways and contributing to a sustainable future.
      LG first started researching glass powder in 1996, and now boasts a total of 219 patents relating to glass powder and its application. The company’s antimicrobial glass powder is made at LG Smart Park in Changwon, South Korea, which produces 4,500 tons of the material annually.
      The antimicrobial glass powder was initially applied to LG ovens launched in North America in 2013. Coating the ovens’ interior surfaces, the glass powder is the key technology enabling the EasyClean function, which brings consumers additional value by making LG’s cooking appliances fast and easy to keep clean.
      “LG is committed to expanding the scope of application for its glass powder beyond that of other glass materials,” said Lyu Jae-cheol, president of LG Electronics Home Appliance & Air Solution Company. “We believe our advanced materials business can help lead the way to a sustainable future, becoming a new growth engine and a central component of LG’s ESG management portfolio.”
      1 The product may not be available for usage in certain markets because of different regulations.
      2 LG’s advanced materials business revised its articles of incorporation last year to include ‘manufacturing and selling functional materials such as glass powder.’
    • By Banty
      Hello, My tv model LG webOS LF5929. In my tv, the lg content store is not opening. when I try to open it shows a network issue. but smart screen share is working perfectly. Give me a solution.
      Complete with Next-Gen Cinematic Technologies, LG OLED TVs are Set to Uncover
      the Hidden Story and Shine Light on the Action of Prime Video’s Latest Hit Series
      SEOUL, April 26, 2023 — Starting this week, LG Smart TV owners worldwide can enjoy Citadel, Prime Video and Amazon Studios’ epic spy-thriller series and the latest global sensation in streaming television. With LG OLED TV’s self-lit technology allowing for deep blacks and life-like color, viewers are placed at the center of the action-packed Citadel universe and can enjoy the show with intended color, aspect ratio and frame rate, thanks to Automatic Filmmaker Mode.* LG OLED TVs also feature Dolby Vision® for stunning ultra vivid picture and incredible immersive Dolby Atmos® sound, which further elevate the cinematic experience.
      Starring Richard Madden and Priyanka Chopra Jonas, Citadel is set after the fall of the titular spy organization, as two spies attempt to piece together what happened. The two spies embark on a mission that takes them around the world, all while contending with a relationship built on secrets, lies and a dangerous-yet-undying love.
      Citadel premieres exclusively on Prime Video on April 28, with two adrenaline-fueled episodes, followed by a new episode released weekly every Friday through May 26. Citadel will be available in more than 240 countries and territories worldwide.
      To mark the launch of the cinematic new television series, Prime Video and LG teamed up to bring the characters and high-tech world of Citadel closer to its fans, through a series of exclusive visuals, rolled out across multiple channels, including online, in-store as well as digital billboards in New York’s Times Square and London’s Piccadilly Circus.
      This is not a first for Prime Video and LG, as it continues a long relationship between the streaming service and smart TV manufacturer. Both have a combined goal to deliver the best viewing experience to millions of customers across the world who stream Prime Video’s great content with the LG OLED evo superior technology.
      From launching link hidden, please login to view on LG OLED TVs in 2015, to movies and series in 2021 and to bringing opted-in for customers to discover the best Prime Video content in 2022, LG’s long relationship with Prime Video continues to lead innovations in the home watching experience.
      “At Prime Video, we are always looking for new ways to innovate and provide our customers the best viewing experience,” said Andrew Bennett Head of Global Video Partnerships for Prime Video, MGM+ and Amazon Freevee. “Our relationship with LG and joint commitment to customers has allowed us to continuously raise the bar with new technology that enhances the overall user experience.”
      This comes as LG aims to boost marketing efforts designed to offer customer value through the delivery of unique experiences across a variety of touchpoints. Prime Video was a natural partner to expand LG’s marketing relationship given their global reach, continued tech innovation and engaging content. LG plans to introduce more exciting collaborations like this in the future.
      “LG is actively collaborating with its content partners like Prime Video to provide customers with an engaging experience on the big screen at home and beyond,” said Chris Jo, senior vice-president of platform business at LG Electronics Home Entertainment Company. “We are happy to kick off this initiative with Prime Video, whose global partnership and shared passion for innovation through the years helps us provide a best-in-class experience for customers.”
      * Available on LG 2023, 2022, 2021, 2020 4K and 8K TVs.
