I'm having an issue with my LG TV & LG Sounbar setup
LG UJ6200 TV software 6.10.55
LG soundbar 33217
ISSUE:  All sound effects EXCEPT movie sound muted, requiring more volume to listen than MOVIE sound effect for live TV and Internet Streaming
TV AUDIO SETTINGS:  Sound out ==> Audio Out (optical/HDMI ARC)
Digital Sound PCM
Simplink: ON
I unplugged the sound power, pressed the power button for 60 seconds ==> no effect
I pressed the volume down button on the sound bar while pressing sound effect on the remote for 60 seconds ==> No effect, did not get reset message.
  • Popular Now
    • By Webos-developer
      Hi LG team,
      We are facing playback issues on LG 2024 and 2025 tv models when we try to play AAC audio content. The content starts playing but after a few seconds it pauses. We have tried with WebOS native player as well as Shaka Player and the behavior is same. We can play the aac audio content on tv models older than 2024.
      Tv model used:
      LG -2025
      Model no - 43UA83006LA/2025
      Type- ultra HD/4kTv
      LG webOS- (10.3.1)
    • By akhilesh malladi
      hi, Friends,
      i have finally fixed the HDMI ARC issue.
      Apparently some people also had the same issue and couldnt figure out whats wrong.
      After reading through AVSForums, I finally understood that LG had a bug in HDMI operation as well..
      The problem happens when your TV is already sending sound through HDMI ARC to a AVR and you try to connect additional sources like dth or blueray player to additional HDMI ports of TV and AVR. Once you add additional sources, you might try to use LG's device connector setting to control the device and this is where HDMI ARC stops working.
      Solution:
      disconnect all hdmi ports of TV and AVR.
      Full reset TV and AVR.
      Only Connect HDMI ARC port of TV with HDMI ARC OUT of AVR. Enable ARC feature on both TV and AVR. Open LG TV internal app,
      and check if sound is coming properly to AVR.
      Now you Connect All additional sources to other HDMI ports of TV and nothing should be connected to AVR.
      You may use LG device connector setting to configure the magic remote to control them.
      MY current setup of TV:
      HDMI 1: Airtel DTH.
      HDMI 2: ARC connected to Denon AVR 1500H.
      HDMI 3: ACT Television(Using this to play hotstar premium content as LG inbuilt APP is not playing it)
      Good news:
      LG magic remote can control all 3 devices seamlessly and thats a great ease for customers.
      I shall appreciate LG for this.
    • By JasonB
    • By RJ Fischer
    • By Regis Wheeler
