webOS 26 broke the Home Assistant integration & remote control!
Popular Now
By stevef
Since my lg-oled65c9pla auto-updated to WebOS 5.5, there is a new bug.
No software has changed in my amp. This is an annoying new bug in the TV software, I assume down to some CEC changes.
By Tosspot
I really love lg tvs hence I now own 3 but what I can’t get past that drives me crazy is any remote turns all tvs on of change Chanel etc and when I’m watching something and the wife changes channel in kitchen tv and the lounge tv chance drives me crazy I’ve unpaired and repaired individually and it still has the same problem
By FUNTIK
By Raxo
Add the option to turn off mouse acceleration. I think I would fins it much easier to aim the pointer if I could disable it. I always disable it on computers. You can just add it next to the pointer speed setting under General > System > Additional Settings > Pointer Options
Two other settings I think would make sense to have would be a setting to disable the shake-remote-to-show-pointer feature. Although I like it I can sometimes find it annoying, so why not let the users decide. I always hate it when there aren't settings for things like these.
The other setting would be to disable the pointer completely as many users have written that they want to disable it.
By MNW
I've had Universal Control via the smart remote sucessfully controlling the audio (volume) for my LG OLED 48C1LB tv via my Sherwood RD-6118R amp for a while now; But following a power cut, the remote no longer controls the amp/tv volume?
The audio IS still being played through the amp using the optical OUT/IN but I have no control of the volume
I've removed and re-initialised the settings for this amp in Universal Control Settings but following the "success" message, the remote does not control the volume on the amp/tv.
What am I missing?
