Tv remote problems
Popular Now
By Raphael Armin
By Raxo
Add the option to turn off mouse acceleration. I think I would fins it much easier to aim the pointer if I could disable it. I always disable it on computers. You can just add it next to the pointer speed setting under General > System > Additional Settings > Pointer Options
Two other settings I think would make sense to have would be a setting to disable the shake-remote-to-show-pointer feature. Although I like it I can sometimes find it annoying, so why not let the users decide. I always hate it when there aren't settings for things like these.
The other setting would be to disable the pointer completely as many users have written that they want to disable it.
By Simon1973
I recently bought a 50NANO90A6B TV and so far I have to say it's a fantastic upgrade from my old Sony 40".
However, I've one small niggle problem (only had the TV since Sunday)... The YouTube app doesn't seem to want to work! it shows the logo with a spinny circle, then the logo starts again with the spinny circle... this just repeats over and over.
All other apps (iPlayer, Jellyfin, Plex, ITV, CH4 etc...) work as does the LGTV app, so the WiFi connection is fine!
I've uninstalled and reinstalled the YouTube app a few times, but it does the same each time!
Anyone know how I can sort this? any other suggestions for fixing it!
I'm currently using my Chromecast with GoogleTV for YouTube at the moment.
I'm in the UK by the way! And the TV is set to that, in all the relevant settings locations.
By GOM43
Last week a LG service person visited our home. After resetting our new LG TV, he went to his van and returned with a large remote controller. We asked what it was for and he told us it was to access settings that the standard controllers could not do. But would not tell us what it did.
Do you know what it can do?
By Dmytro Fadyeyenko
My 65UQ70 TV started to ignore my remote yesterday. After some experiments I've found that it only reacts to double clicks now. So I have to use double clicks for any action - move through menus, launch apps etc, single clicks are just ignored.
Resetting the TV to factory settings didn't help.
I tried to google the issue and found that this might be an issue with the remote, but I can't find how to reset the remote of my model. Combinations like Home+Back (for Magic Remote) or 2+8 (for some old style remotes) don't work for my model, neither removing batteries and pressing all buttons does.
My remote seems to be AKB76040302, a photo from the Internet is below.
So, how do I reset it?
Some other things to mention:
- The pulses of the remote are not visible through a cell phone camera, so I couldn't check if it only sends signals to the TV after double clicks, or the TV is enforcing this issue. UPDATE: a cellphone sees the pulses in darkness, and a pulse is sent on each press, not only on doubles. So it should be TV OS issue, not the remote issue.
- This started to happen after I have updated the software and connected a sound bar with optical cable, though I believe the last action isn't related to the issue.
Tosspot
I really love lg tvs hence I now own 3 but what I can’t get past that drives me crazy is any remote turns all tvs on of change Chanel etc and when I’m watching something and the wife changes channel in kitchen tv and the lounge tv chance drives me crazy I’ve unpaired and repaired individually and it still has the same problem
