Prime Video unable to update/install on LG TV OLED65G36LA WebOs 8.20.0-710
Popular Now
By Raphael Armin
By stevef
Since my lg-oled65c9pla auto-updated to WebOS 5.5, there is a new bug.
No software has changed in my amp. This is an annoying new bug in the TV software, I assume down to some CEC changes.
By FUNTIK
By FUNTIK
By german_donkey
I have a TV oled65c5elb with webos25 10.2.1-5504.
I programmed in Home assistant a few Dashboard to contol the TV. I can Switch the Channels from live TV by Home Assistant. But Not in LG Channels or other Apps Like Pluto TV. If someone can Help me, please Post it. Thank you.
Juicycarrot
Hi there,
I have an LG smart TV OLED65G36LA (LG OS v03.20.17, webOS TV version 8.20.0-710) , and the Prime Video App was no longer able to update (from Dec 2025) and therefore could no longer be used.
I have tried uninstalling the app and re-installing, and that was unable to work, so then applied a full reset on the LG TV and so had to reinstall all of my other apps (Apple TV, Netflix, etc etc) which all successfully downloaded so confirmed network connections and setup are all confirmed working.
When I try to download the Prime Video app, it remains stuck on the download screen and is unable to update.
3 answers to this question
