Password not retained after poweroff
Popular Now
By Matt79
I've just updated my LG 55UM75 TV to the latest software version - 05..20.15 - and now the picture looks off.
I've turned off TruMotion, Motion Eye Care, Smooth Gradation, Noise Reduction and Smooth Gradation, but somehow everything still looks artificial.
Is there another picture setting I'm missing, I've gone through every setting I can find.
By Dscottbellamy
how can I fix lg soundbar model sn6y volume automatically going down after exactly 30 minutes if resetting, unhooking volume down button, drilling vent holes near motherboard, and running a cooling fan did not fix the problem.
By bohatier
TV model: OLED55B13LA
Example:
By Low Grade
i always have to turn off the TV using the power switch (put on standby won't do) to view ''live tv'' channels again after watching LG Channels................any way to do that without powering off the tv completely ? 😟
By Chi
I'm urgently looking for a way to watch video files that are accessible via different SMB-shares - I was able to do that with external devices like WD-TV-HD Media Player or a raspberry pie - and I thought that I will not need that any more with my new LG OLED - I can webOS or which APP I need to install on the TV to do that
I was expecting to see accessible SMB shares - where I can enter or even store user/pw - besides the Sticks/HDDs attached to the USB port
In the Internet I just found solutions by hacking / manipulating webOS - I cannot believe that this is the correct/only way to achieve that...
TIA,
Chi
