Hi All,
My TV will only display a good pisture when using 1080 sdr 30hz. Anything different and certain content will appear washed out, blue or green tint on setup and streaming pages. I believe my TV is connected correctly as the picture is fine so long as it is 1080 sdr. Thoughts?
Thanks in advance
My
  • 2 weeks later...
Please quote model number and firmware level, and if it is connected via an AVR and set-top-box, and if using eARC. Model numbers of those might help narrow down the issue, plus what is the HDMI connection order between devices.
  • Popular Now
    • By Ramesh Chand Vishwakarma
      Regards,
      MD/CEO
      Noida, UP
      +91 9910246766
    • By Raphael Armin
    • By stevef
      Since my lg-oled65c9pla auto-updated to WebOS 5.5, there is a new bug.
      No software has changed in my amp.  This is an annoying new bug in the TV software, I assume down to some CEC changes.
    • By FUNTIK
    • By FUNTIK
