Bluetooth not connect and not discover any sound output
After software update the bluetooth of my 43UR78003LK.AEU TV not work. Can't discover new sound output and can't connect to headset. It's new problem, before update it worked fine.
Model is 43UR781C0LK
Software version is 23.25.40
webOS TV version is 9.2.2-58
What can I do?
Thanks, Best regards.
Zoltan
  • Popular Now
    • By mesplint
      I have a LG 65QNED92AUA tv that has issues with the Bluetooth connection dropping off when connected to my earbuds. I believe the issue to be software related. LG has sent 2 technicians out to repair and the first technician changed the main board and Bluetooth transmitter which did not resolve the issue.
      There are similar issues with Bluetooth Connection from others.
      Since hardware replacement didn’t help and this is a known software-pattern issue, I would like push LG to specifically address it at the firmware/webOS level. I am unable to escalate to their software team and check if there’s a known patch or beta firmware for the QNED92 line.
      For some reason this line of questioning is not available with in LG customer service.
       Please help!
    • By Fredrik Andersson
    • By chris7ben
      The sound and picture are out of sync when screen mirroring from my iPhone 16 Pro to my LGQNED70A6A TV, using the internal speaker. I have tried all the recommended tips in the settings to cure the issue with no success. However, when I isolate the TV from the mains supply for 60 seconds and restart it, the syncing issue is cured but degrades after a day or so. My iPhone software is up to date and there is no firmware upgrade available for the TV. My LinkSys router has a full fibre connection. The only connection into the TV is the mains supply. Any help much appreciated. Thanks in advance.
    • By hjetschko
      Hi, I have a feature request for the sound out setting. I often connect my Bluetooth headphones to the TV. We don't use the internal speaker of the TV, we use the optical sound out setting whenever I don't use Bluetooth. It would make our lives a lot easier if the TV can remember the last sound out setting before connecting to Bluetooth and default back to this setting when the Bluetooth device gets disconnected. At the moment, each time I disconnect the headphones I have to go back into settings and change the sound out setting from internal speaker to optical again.
      Thanks and regards
      Hubert
    • By John Peet
      TV is a week old and the internal speaker has stopped working when in HDMI ARC + internal speaker sound output mode. The internal speaker itself works fine when in “internal speaker” sound output mode. I’ve checked all the settings that I can and can’t find anything that would correct this issue.
