Privacy "CMP settings": consent for "Google Vendors" doesn't save, it does for "IAB Vendors"
Popular Now
By Cody94549
By Raxo
Add the option to turn off mouse acceleration. I think I would fins it much easier to aim the pointer if I could disable it. I always disable it on computers. You can just add it next to the pointer speed setting under General > System > Additional Settings > Pointer Options
Two other settings I think would make sense to have would be a setting to disable the shake-remote-to-show-pointer feature. Although I like it I can sometimes find it annoying, so why not let the users decide. I always hate it when there aren't settings for things like these.
The other setting would be to disable the pointer completely as many users have written that they want to disable it.
By MNW
I've had Universal Control via the smart remote sucessfully controlling the audio (volume) for my LG OLED 48C1LB tv via my Sherwood RD-6118R amp for a while now; But following a power cut, the remote no longer controls the amp/tv volume?
The audio IS still being played through the amp using the optical OUT/IN but I have no control of the volume
I've removed and re-initialised the settings for this amp in Universal Control Settings but following the "success" message, the remote does not control the volume on the amp/tv.
What am I missing?
By yosis
Hey All,
I have google TV which connected with HDMI to my LG
It worked perfectly first few days and I was able to fully control the TV with remote
It suddenly stopped working yesterday and i cant contol the tv from remote of the google tv
I did factory reset to google tv but didn't help
I do see that controlling enabled both on tv and streamer but still dead. Any ideas?
By thutch79
When in an app, hitting home on the remote doesn't do anything. I was looking to see if there's a webOS update available, and now I see trying to open settings locks it all up. The only way to get out of an app right now or get it out of the state where trying settings locks it up is to power off and back on again.
Things I've tried:
1. Restart. I've tried various ways including unplugging and holding the power button on the TV for a while. I left it unplugged all night.
2. Repair of the remote.
I don't know what else to try as I can't even get into settings to see if there's an update to fix this mess. Any thoughts?
LG OLED person
In "CMP settings": there is a huge list of vendors, IAB and Google.
You can deselect consent for those.
However when you go back, in the Google consent are all still enabled.
Reject All doesn;t work. Deselecting individually and clicking "Confirm my choices" doesn't work. The Google ones are back on.
That's really bad, GDPR.
oled55c24la, update 23.25.55
