LG OLED65C2AUA.
webOS TV version webOS25/10.2.2-61. up to date.
software version 33/22.95 up to date.
whenever I watch Netflix it freezes indiscriminately. Once it happened at minute 1:29 of a movie although it can happen at any time. the Netflix error message says to restart which I do but the issue persists. it is to the point where it is unwatchable. however, when I watch it through Firestick it is fine. Other TV's do not have the issue so I am thinking it is something with the TV. I have uninstalled and reinstalled the app on the TV. I have powered down the TV. I have reset the router. I am wired with ethernet so not using wifi. any help would be appreciated to fix this issue.
  • Popular Now
    • By Dennis p
      Hi!
      I own a OLED65C8PUA 65-Inch 4K Ultra HD Smart OLED TV and it seems to be suddenly freezing when a commercial starts on a LG channel. I've unplugged the TV, hold down the start button, restarted to clean out the cache. I even restarted the whole system where it deletes most of the apps and all your picture and internet settings. Still getting this freeze during ADS between the LG channel presentations (be it the 80's, 90's, Love Boat channels, etc.) Anyone else have this problem? I'm kind of at a loss of what to do next.
    • By Nicola123
    • By svsrama
      Sriram.
    • By cptl
      Any thoughts?
    • By Sandtonman
      Dolby Vision is 22.11.
