LG FIX YOUTUBE!
Popular Now
By Uuganbayar
there is no youtube app in TV home. even in apps store there is no youtube. TV model 65NU900B6LA
By FUNTIK
By FUNTIK
By Simon1973
I recently bought a 50NANO90A6B TV and so far I have to say it's a fantastic upgrade from my old Sony 40".
However, I've one small niggle problem (only had the TV since Sunday)... The YouTube app doesn't seem to want to work! it shows the logo with a spinny circle, then the logo starts again with the spinny circle... this just repeats over and over.
All other apps (iPlayer, Jellyfin, Plex, ITV, CH4 etc...) work as does the LGTV app, so the WiFi connection is fine!
I've uninstalled and reinstalled the YouTube app a few times, but it does the same each time!
Anyone know how I can sort this? any other suggestions for fixing it!
I'm currently using my Chromecast with GoogleTV for YouTube at the moment.
I'm in the UK by the way! And the TV is set to that, in all the relevant settings locations.
By bohatier
TV model: OLED55B13LA
Example:
