Change Lay-out of the Smarthub
Popular Now
By akacabo
I am trying to change my tv region from middle East to USA but changing won't take effect
What should I do here that I am missing
By tazcox
hello
i have buy a 55UB850V , i'm really happy for the quality but during a tv show i can't change the audio language ..
on my la 690 i can choose the audio language with the menu Q-menu ..
i can't find this menu on the UB...
anyone could help me ?
By Raus
Hello, I know that other LG WebOS users have the same problem as me, but I can't find a solution on the web.
Perhaps one of you experts can help me.
Shortly: manually sort the app icons on my LG Smart TV (OLED77C55LA) and place the “TV Channels” icon in the first position (on the left, to be clear). Before all the others (e.g. Netflix, PlutoTV, Prime, etc.), but when I turn off the TV for a few hours and turn it back on, I find the “TV Channels” icon in last position.
I have tried putting it in second position, third position and so on, but every time I turn it back on, I find it in last position.
Can anyone help me?
Thank you.
By SQLGuy
Hello, I have a US mode 65UM7300AUE (Costco model) that I brought with me when I moved to France. I would like to be able to install apps from the French content store.
I can get into the service menu, but all the Country Group fields seem to be read only. Is it possible to change these?
Paul
By jmk
My LG TV : Model 75UM7000PLA
The Problem:
When I want to use my wireless optical headphones, I switch the TV “Sound Out” option to “Optical” or “Internal TV Speaker + Optical.” But when I do this, the TV sends a command to the Yamaha receiver that forces it to switch its input to Optical. This stops playback of my HDMI device connected to the Yamaha because the Yamaha input is changed.
What I would like:
Can LG update the TV firmware so that:
1️⃣ When I select “Optical” or “Internal TV Speaker + Optical” in “Sound Out,” it does not cause the Yamaha receiver to switch its input source?
OR
2️⃣ Add a new “Sound Out” option that sends audio to Optical without sending a command to change the Yamaha input?
OR
3️⃣ Make the existing “Internal TV Speaker” mode also output audio through Optical, but without causing the Yamaha input to switch?
Note:
Disabling ARC is not a good solution because:
Audio from devices connected to the Yamaha receiver still plays on both TV and Yamaha speakers.
Audio from devices connected to the TV no longer plays on the Yamaha speakers.
Thank you!
Hemant_5400z
Hi All,
I have an LG Oled65C554, I know I I can rearrange the apps screen. What I cannot seem to figure out is how to arrange/re-arrange the smart hub lay.
On the left I have the Input and a scroll, however on the right side I have a BIG part that takes LG smart divices en IOT-devices which is empty as I don't have ohte LG appliances.
I woul like to get rid of the right part on the screen or even better add my hoemkit devices to the dashboard(not sure if that will be possible).
Anyone who got this working?
