Default admin PWD not working after firmware updates
I've update 2 of my LG Digital signage TVs (Model 65UH5J-HP) to the latest firmware (3.74.00). Before updating I was able to access the admin menu using "000000" as the default PWD. After updating, I am no longer able to use that default password to access the admin menu. It's giving me a message saying "Incorrect password (Same number repeated). Please try again"
I tried to usual suspects:
123456
654321
111111
666666
No bueno  - anyone got any insights?  LG corporate support was unable to help either.
  • Popular Now
    • By NaveenKumar
    • By Matt79
      I've just updated my LG 55UM75 TV to the latest software version - 05..20.15 - and now the picture looks off.
      I've turned off TruMotion, Motion Eye Care, Smooth Gradation, Noise Reduction and Smooth Gradation, but somehow everything still looks artificial.
      Is there another picture setting I'm missing, I've gone through every setting I can find.
    • By jikhead
      I'm not getting any audio from the apps via the HDMI via ARC connection to my receiver.  This occurred two weeks ago and was unable to resolve it, but ironically there was new firmware released that same day for my B6 (3/31/17) and this fixed the issue.  However, now I again can't get it working after a TV reset and tinkering with the audio settings again.  I tried to load the firmware again, but it appears this is not possible to forceable load the same firmware.
    • By Dscottbellamy
      how can I fix lg soundbar model sn6y volume automatically going down after exactly 30 minutes if resetting, unhooking volume down button, drilling vent holes near motherboard, and running a cooling fan did not fix the problem.
    • By bohatier
      TV model: OLED55B13LA
      Example:
