close captioning is lagging on several, but no all, channels
Popular Now
By Charley
On my LG 'smart' TV now for some reason I can now only watch the LG channels but not the fiber-optic programming on wi-fi . The HDMI 1 feed I normally use shows 'dark' on the Dashboard even though I can get the green checkmark on it. How do I reconnect it? The Dashboard shows my feed as ethernet/cable; which is wrong but efforts to correct it have failed so far.
Chemicals Industry -
By andystaffs
It seems our LG TV has done an update which has removed the "standard " BBC channels from the guide . After one day BBC2 has reappeared . The HD channels are present though . I've done a re-scan but no change . I've looked to see if we can move BBC1 HD (on 101) to Chanel 1 on the guide but doesn't seem to be an option.
Anybody else have this problem and any cures ?
By Low Grade
i always have to turn off the TV using the power switch (put on standby won't do) to view ''live tv'' channels again after watching LG Channels................any way to do that without powering off the tv completely ? 😟
By ColinMawbey
TLC on Freesat ....Channels 144 & 150 have become scrambled... screen shows No CI MODULE...as far as i know this OLED 65C4 tv does not have the Module fitted..tried a reset, & checked cable connections all good,,, both channels work fine on freeview, any help out there....
barrystevenson
The close captioning is lagging in most of our network channels. PBS is the only channel that close captioning works consistently on.
