Bugs after 33.20.66 update on c3
Popular Now
By Interstellarkev
This is for all that have LG monitors with the latest software that changed UI settings for GAME OPTIMIZER
I could not find this anywhere on the internet for an update on what happened to the compatibility modes for DisplayPort/HDMI. Everything is outdated.
Apparently LG updated their UI and MOVED the option for compatibility modes to disable DSC. This USED to be in the common GENERAL tab, but NO LG moved it to the External Devices, which makes no sense as it should be with the common general menu.
I'm not sure if this is a bug or an oversight, but here it is
SETTINGS BUTTON > GENERAL > EXTERNAL DEVICES > INPUT COMPATIBILITY
Why would you disable DSC, you ask?
Well, if you don't disable this mode, you will not be able to use scaling factors like DSR on NVIDIA. I have seen remarks about AMD being able to use it without this option turned off, but for NVIDIA they are behind on this.
This WILL disable high frame rates beyond 144 Hz for the trade-off, but you will be able to scale your resolution higher.
TESTED 1.4dsc off (full dsr support higher res)
By stevef
Since my lg-oled65c9pla auto-updated to WebOS 5.5, there is a new bug.
No software has changed in my amp. This is an annoying new bug in the TV software, I assume down to some CEC changes.
By Matt79
I've just updated my LG 55UM75 TV to the latest software version - 05..20.15 - and now the picture looks off.
I've turned off TruMotion, Motion Eye Care, Smooth Gradation, Noise Reduction and Smooth Gradation, but somehow everything still looks artificial.
Is there another picture setting I'm missing, I've gone through every setting I can find.
By Dscottbellamy
how can I fix lg soundbar model sn6y volume automatically going down after exactly 30 minutes if resetting, unhooking volume down button, drilling vent holes near motherboard, and running a cooling fan did not fix the problem.
oled 65 c3 user 314
After the 33.20.66 update what are the known issues?
