LG C4 usb ports stay active after power off
Popular Now
By starwoodtech
By Matt79
I've just updated my LG 55UM75 TV to the latest software version - 05..20.15 - and now the picture looks off.
I've turned off TruMotion, Motion Eye Care, Smooth Gradation, Noise Reduction and Smooth Gradation, but somehow everything still looks artificial.
Is there another picture setting I'm missing, I've gone through every setting I can find.
By Dscottbellamy
how can I fix lg soundbar model sn6y volume automatically going down after exactly 30 minutes if resetting, unhooking volume down button, drilling vent holes near motherboard, and running a cooling fan did not fix the problem.
By bohatier
TV model: OLED55B13LA
Example:
By Low Grade
i always have to turn off the TV using the power switch (put on standby won't do) to view ''live tv'' channels again after watching LG Channels................any way to do that without powering off the tv completely ? 😟
Imagienthatca
I have been using led strip in the back of the LG C4 tv, I lugged into the TV usb port. Usually the turn on when the TV turns on, and turn off when the TV is turned off. Starting today, the led strip stays on after the TV is turned off, meaning the USB port must be remaining active. I have checked and tried every setting I can see in the TV settings but nothing changes. How to make the usb ports turn off when the tv is turned off?
