LG Launches 4K Surgical Monitor With Intelligent Features To Optimize Surgical Workflow
31.5-inch Surgical Monitor Boosts Convenience in the OR With Intelligent Features
Including Preset Picture Modes and Instant Screen Mode Switching
SEOUL, Sep. 11, 2025 — LG Electronics (LG) is launching its new 31.5-inch 4K surgical monitor, model 32HS710S. Designed to streamline surgical workflow, the monitor combines crisp 4K resolution (3,840 x 2,160) image quality with intelligent new features that prioritize user convenience and operational efficiency. The monitor has received 510(k) clearance from the U.S. FDA, confirming it can now be sold in the U.S.
The 32HS710S introduces a range of workflow-enhancing functions to make it simpler and more intuitive for medical professionals to interact with visual data. For example, users can configure picture mode settings independently for each input source, helping to display images from multiple devices in a way that suits their needs. Dedicated hotkeys enable quick activation of preferred screen modes and Picture-by-Picture (PBP) layouts, facilitating adjustments with a single button press.
The monitor’s 4K IPS display is designed to deliver clear, detailed images with consistent color across a wide viewing angle. It provides a typical brightness of 800 cd/m² and covers approximately 95 percent of the DCI-P3 color space. Compliant with the Digital Imaging and Communications in Medicine (DICOM) standard, the monitor is a high-quality solution for displaying visual output from various medical imaging devices.
To address the demands of the operating room environment, the 32HS710S employs durable glass with Optical Bonding, along with Anti-Glare, Anti-Reflection and Anti-Fingerprint coatings to help maintain image clarity under bright surgical lighting. The monitor is built with an IP45 rating for the front, IP32 rating for the back and IK06 impact resistance. Weighing approximately 9.2 kilograms, it can be mounted on a variety of surgical monitor arms.
For operational continuity, the monitor includes a Failover Input Switch that can automatically switch to a backup source if the primary signal is interrupted. This key reliability feature is complemented by versatile viewing options, including 4-screen PBP and Picture-in-Picture (PIP) for monitoring multiple sources at once. The display also offers Mirror and Rotation Modes for the easy adjustment of image orientation, and Clone Screen output for training and collaboration purposes.
“In developing the 32HS710S, we concentrated on delivering practical workflow benefits for surgical teams – for whom time and focus are critical,” said YS Lee, head of the IT Business at the LG Media Entertainment Solution Company. “By incorporating automated screen settings, one-touch controls and reliable backup systems, we aim to provide tools that can help medical staff maintain focus on patient care.”
To learn how LG’s advanced medical displays can enhance image color and clarity surgical precision and optimize surgical operating room workflows,
for more information and to request a consultation.
Key Specifications:
LG Surgical Monitor
(32HS710S)
Display Panel Type IPS
Size (Aspect Ratio) 31.5-inch (16:9)
Resolution 4K (3,840 x 2,160)
Backlight Technology LED
Color Gamut (Typ.) DCI-P3 95% (CIE1976)
Color Bit 10bit
Viewing Angle (CR≥10) 178° (Right / Left), 178° (Up / Down)
Brightness (Typ.) 800cd/m²
Brightness
(Stabilization)
500cd/m²
Surface Treatment Protection Glass (Optical Bonding, Anti-Reflection, Anti-Fingerprint, Anti-Glare)
Contrast Ratio (Typ.) 1,000:1
Response Time
(GtG1)
5 ms (GtG at Faster)
Features DICOM Compliant Yes
Hardware Calibration Yes (LG Calibration Studio)
HDR HDR 10, HDR Effect
Video Signals Input Terminals HDMI x 1, DisplayPort x 1, SDI (3G) x 1, DVI-D x 1
Output Terminals HDMI (Clone Screen) x 1, SDI (3G) x 1
Connectivity USB USB 3.0 1 Upstream, 1 Downstream
Power AC Input 100-240 Vac, 50/60 Hz
Power Consumption 100W (Max) / Less than 0.3W (DC Off)
Durability IP Resistance Rating2 IP453 (Front), IP324 (Except for Front), IK065
User
Convenience
PBP / PIP Yes (2 / 3 / 4 PBP) / Yes
Screen Flip Mirror Mode & Rotation Mode
Failover Input Switch Yes
Physical
Specifications
Weight 9.2 kg
Wall Mount Size 200 x 100 mm / 100 x 100 mm
2 Tested under controlled laboratory conditions with an IP / IK rating. Dry before using. Do not charge while wet.
3 IP45: Protected against solid foreign objects of 1.0 mm Ø and greater / Protected against access to hazardous parts with a wire / Protected against water jets.
4 IP32: Protected against solid foreign objects of 2.5 mm Ø and greater / Protected against access to hazardous parts with a tool / Protected against vertically falling water drops when enclosure tilted up to 15°.
5 IK06: Protected against 1 joule impacts.
* Specifications may vary by region and all features, standards and other product specifications are subject to change without notice or obligation.
  • Popular Now
      The way we work, learn and shop is changing fast. With hybrid work becoming the norm, education going digital and the lines between online and offline experiences blurring, there’s a growing need for technology that can keep up. Businesses today need tools that are flexible, easy to use and ready to adapt to whatever the day brings.
      That’s exactly why we created the LG Smart Monitor Swing (model 32U889SA) – an all-in-one display engineered for modern enterprises. It’s a versatile smart platform that works without a PC, so you can use it anywhere, anytime, to boost productivity, improve communication and create better experiences for customers, students and teams.
      Let’s take a look at how it’s making a difference across different spaces.
      Retail: Overcoming In-Store Communication Hurdles
      In retail – particularly in fashion and beauty – it’s all about catching the customer’s eye and sharing the right information at the right time. But we know that installing large, fixed displays isn’t always easy in busy stores.
      The LG Smart Monitor Swing directly addresses these issues. Its vibrant 4K (3,840 x 2,160) resolution display serves as a dynamic digital catalog, showcasing product details and promotions with stunning clarity. Furthermore, its movable stand overcomes installation barriers, allowing for flexible placement anywhere in-store. This enables retailers to strategically position the display to capture customer attention or instantly repurpose a space for a live commerce broadcast – maximizing both engagement and floor space.
      Hospitals: A Dynamic Information Hub for Patients and Visitors
      Hospitals are busy places, and keeping patients and visitors informed can be a challenge. Static posters and signs can be missed, and updating them takes time.
      With the Smart Monitor Swing, you can easily share schedules, health notices or service information in real time. Place it at the front desk to welcome visitors, in waiting areas as a digital bulletin board or even use it as a central hub for teleconsultations. And because it’s mobile, you can move it wherever it’s needed most – no more being tied to one spot.
      Education: Transforming Passive Viewing into Interactive Learning
      A common challenge in educational settings, from kindergartens to senior classrooms, is fostering sustained student engagement and enabling meaningful real-time interaction. The Swing transforms the learning process by creating a more collaborative and effective environment.
      Its adjustable, high-resolution screen provides an optimal viewing experience for remote learning and group activities. Powered by webOS, the smart monitor lets students and teachers directly interact with educational applications and whiteboard functions via its touch-sensitive screen, turning passive viewing into an active, participatory experience.
      Workspaces: Redefining Collaboration and Personal Productivity
      In small offices or meeting rooms, space is precious. The Smart Monitor Swing can be your team’s central hub for sharing ideas, running video calls or working on cloud-based apps.
      With its 31.5-inch 4K screen, it’s perfect for sharing content with small groups. Its built-in webOS platform further enhances collaboration by allowing teams to access home office apps, including video conferencing apps2 and cloud-based applications – all without needing an external device such as a laptop or PC.
      The Swing’s versatility also introduces a new way of working for professionals who value a clutter-free desk, such as fashion designers who need space for physical samples. Its unique, independent stand liberates the entire desk surface for a clean workspace. The large display, combined with versatile tilt, swivel and pivot functions, makes it easy to hold spontaneous discussions over materials, fostering a more dynamic and interactive workflow.
      Sports & Entertainment: From Simple Simulators to Premium Experiences
      Sports and entertainment venues often face space constraints that make it difficult to install or reposition large displays. The Swing provides a mobile and flexible solution, delivering large, high-resolution screens that can adapt to different environments. In screen golf facilities, for example, its innovative swinging design enables optimal positioning and effortless repositioning. Featuring stunning 4K resolution, the Swing delivers a more immersive player experience than the low-resolution screens found in many simulators, rendering highly detailed course graphics. Powered by webOS, it also supports seamless customization of club branding, promotional events and time-based announcements.
      The versatility extends to various hospitality applications. In hotels and VIP lounges, it ensures vivid visuals for branded content, promotions and event information. When placed in business hotel rooms, the monitor allows guests to work conveniently, using webOS apps to maintain productivity without a PC.
      For us, the LG Smart Monitor Swing isn’t just another screen – it’s a core enterprise solution that helps businesses work smarter, communicate better and make the most of their space. And we’re not stopping here. We’ll keep creating innovative display solutions that break free from the limits of traditional monitors, so you can keep adapting, growing and thriving.
      Ready to transform your business environment with the LG Smart Monitor Swing?
      link hidden, please login to view to discover how this versatile display can be tailored to your specific needs. # # #
      1 All images are simulated to enhance the reader’s understanding.
      2 Webcam (with microphone) required for video conferencing. Sold separately.
      A Future-Proof Display for Professional Video Editors and Designers, Delivering 6K
      Resolution, Precise Colors and High-Speed Connectivity
      SEOUL, Sep. 30, 2025 — LG Electronics (LG) is introducing the UltraFine evo 6K (model 32U990A), the world’s first 6K monitor with Thunderbolt 5 connectivity. Debuting under LG’s new UltraFine evo brand of premium, ultra-high-resolution monitors, the 32U990A is purpose-built for professional video editors, graphic designers and other creators working with demanding, data-intensive workflows. Combining ultra-sharp 6K resolution (6,144 x 3,456) with exceptional color accuracy and high-speed connectivity, it empowers users to work faster and smarter.
      The 32U990A – the first-ever 6K display with Thunderbolt 5 support – has already earned a CES 2025 Innovation Award and the iF Design Award 2025. Building on the legacy of LG UltraFine series – a line of 5K displays optimized for Mac devices – the UltraFine evo brand raises the bar for professional-grade displays even higher, as clearly demonstrated by the superb performance and impressive capabilities of this inaugural model.
      LG’s premium monitor is designed to meet the needs of creative professionals, providing flawless image fidelity and next-level text clarity. Its 32-inch 6K HiDPI display boasts a pixel density of 224 PPI, delivering sharper, cleaner text and precise visual details. Factory-calibrated for consistent color expression with macOS, the 6K UltraFine evo covers 98 percent of the DCI-P3 color space and 99.5 percent of Adobe RGB, ensuring faithful image reproduction for video and image editing as well as print production. VESA DisplayHDR 600-certified, it maintains the consistent brightness and true colors required for detailed graphics and video work. Additionally, Studio Mode* featuring three color preset options for Mac devices will be introduced.
      Designed with professional users in mind, the 32U990A’s 6K resolution delivers 2.56 times more pixels than a UHD 4K resolution (3,840 x 2,160) monitor. When two 6K UltraFine evo monitors are set up in a dual configuration, users can achieve a massive workspace with nearly five times the screen real estate of a single UHD 4K monitor. A particular advantage for Thunderbolt based systems, this multi-monitor setup is easily facilitated via daisy-chaining, further enhancing multitasking efficiency and optimizing digital workflows.
      The new monitor also serves as a professional hub with built-in KVM switching and multi-port connectivity, enabling seamless operation across Mac- and Windows-based systems. This allows creators to view mobile content in the optimal format while simultaneously working on production tasks.
      Thunderbolt 5 compatibility ensures effortless integration with Mac devices while serving as a high-speed hub for SSDs, eGPUs and other peripherals. Offering up to 120Gbps unidirectional data transfer – three times faster than Thunderbolt 4 – it supports real-time 4K rendering and rapid transfer of 8K RAW video files, making the 32U990A ideal for AI-powered video editing and upscaling workflows.
      Visually striking as well as powerful, the monitor’s 4-side Virtually Borderless design delivers a clean, minimalist aesthetic and immersive viewing experience. Ergonomic tilt and pivot adjustments allow for comfortable long-session editing and make it ideal for vertical-format content such as YouTube Shorts and Instagram Reels. Thunderbolt 5 also helps reduce cable clutter, keeping workspaces neat while enabling flexible multi-monitor configurations.
      “With many video editors now managing high-volume, multi-project workflows, the need for ultra-high-resolution displays with precise color and fast connectivity has never been greater,” said YS Lee, head of the IT Business at the LG Media Entertainment Solution Company. “A future-proof display of uncompromising quality, the new UltraFine evo 6K more than meets this need, helping professional creators work faster, smarter and deliver their best results.”
      The UltraFine evo 6K monitor will begin its rollout in late September in South Korea and Japan, with a global launch including the U.S. and Europe to follow in October.
      * Availability of this feature on select early production units may require a firmware update through LG Switch
      Great design doesn’t stand still. It moves with you, blending seamlessly into your daily routine and elevating ordinary spaces into places of inspiration. That’s why we created the LG Smart Monitor Swing – a monitor that flows between productivity and relaxation, turning a focused workspace into a cozy spot to unwind. True to its name, the Swing moves freely, letting you tilt, swivel and adjust the angle or distance to fit your lifestyle.
      Closer For Work, Farther For Play
      Why “Swing”? Because its name says it all – freedom and versatility. A desk is no longer just a place for work. Swing boosts productivity when you need to focus, and just as easily transforms the space into a cozy, relaxing corner when it’s time to unwind.
      Work Smarter With Precision and Clarity
      The moment you get closer to Swing is when it’s time to work. Its Dynamic Tone Mapping, which delivers a wide view and true-to-original visuals, makes it an ideal choice for those who frequently edit photos and videos. The large 32-inch 4K UHD (3840×2160) IPS touchscreen offers exceptional detail, providing greater satisfaction for creators who demand precision. What makes it even better is Swing’s flexibility–it can be adjusted freely to fit your body, allowing you to maintain the most comfortable posture at all times.
      This balance of power and precision is exactly what creators value. @jennyhomemood described the Swing’s image quality as “almost like using an oversized smartphone,” adding that its clarity made it especially useful for video editing and monitoring.
      Likewise, @kim___hihi__7878 highlighted its easy mobility, noting how she uses it seamlessly in the living room, kitchen and bedroom. She especially praised the touchscreen and mirroring features, which allow her to project a small laptop screen onto the larger display at eye level for a far more comfortable experience.
      Smartphones have made us fluent in touch. Swing takes that same ease and brings it to your desk, with button-free, intuitive control that feels natural and effortlessly convenient.
      Relax at a Distance, Control With Ease
      Moving seamlessly between the living room, kitchen and bedroom, the Swing also fits naturally into any lifestyle after working hours. For @haneul__home, the Swing fits perfectly into her lifestyle. From working at her sewing machine, to checking recipes in the kitchen, to relaxing with a movie, she found it useful everywhere. She also noted how it enhances her home décor, blending seamlessly into any space while adding a premium touch.
      Even after work, the Swing stays with you. Sometimes all you need is a little distance – and Swing makes it effortless to move closer or farther with smooth, fluid motion. With the included remote, convenience is always within reach. Plus, the LG ThinQ app turns your smartphone into a controller, so there’s no need to carry an extra remote from room to room.
      Tilt and Swivel to Follow Your Eyes, Match Your Posture
      Swing puts people at the center. You don’t have to adjust yourself to the monitor – the monitor adjusts to you. With finely tuned joints, Swing follows your gaze and adapts to your posture, giving you the freedom to set it exactly the way you want.
      My Personalized Tilt – Comfort, Even When You Lie Back
      This adaptability is what makes Swing feel like a personal companion in daily life. To @jennyhomemood, this adaptability makes the Swing feels like a personal companion, keeping her company at the table when eating alone or adjusting to different angles during workouts. Whether lying in bed or sitting at your desk, the tilt function allows you to change the angle until it feels just right, ensuring your neck and shoulders stay comfortable.
      Whether lying down or sitting up, Swing adjusts to the angle that feels just right. Thanks to its tilt function, your neck and shoulders stay comfortable no matter the situation.
      Swivel with You, Share the View
      Watching a movie with family, working alongside a friend or sharing a screen during a meeting – this is where Swing’s swivel function shines. No need to drag a chair or shift your posture. Just give the screen a gentle turn, and you’re ready to share.
      Its smooth, effortless swivel not only makes collaboration more efficient but also brings people closer – strengthening bonds with colleagues, friends and family alike.
      Sit, Stand or Lounge, Comfort Tailored to You
      The Swing offers height adjustment of up to 329mm, providing comfort that perfectly matches your eye level and posture. Use it while sitting at a desk, standing, lying down or even sitting on the floor with children.
      Especially for those accustomed to floor seating – common in Korean homes – the Swing adapts beautifully. Whether leaning back on a sofa or sitting low to the ground, the monitor adjusts effortlessly to your eye line. With this flexibility, Swing’s appeal only grows stronger, making it the perfect fit for any lifestyle.
      Reflecting on her own experience, @haneul__home noted that being able to adjust the angle and height made a tangible difference: she felt less strain on her shoulders and neck, and appreciated that the monitor could be set at the ideal eye level not only for herself but also for her children.
      The right height alone can make a big difference in reducing body fatigue. With its flexible comfort, Swing adapts not only to work and relaxation but also to every member of the family – from small children to adults – making it the perfect fit for everyone.
      Desk To Task, Work To Life – All With Free Beauty
      While many products may look similar on the surface, Swing stands apart with design details that go beyond what meets the eye. Co-created by LG’s designers and engineers, it reflects a level of precision and craftsmanship that becomes more evident the longer you use it. The seamless harmony of function and design elevates the quality of everyday life.
      Swing proves why LG is the true pioneer of the mobile stand category. Countless reviews highlight the difference: “You can tell it’s LG just by the stand – others are mere imitations,” and “It’s the attention to every tiny detail that sets it on another level.”
      Echoing this, @ijuyeon157 emphasized how effortlessly the Swing moves around the house thanks to its five-wheel base. She praised its clean, minimalist white design that brightens up her home, and its flexibility to adapt to different needs – from her son’s studies to her own movie time. For her, Swing was the only product that could adjust so precisely to every situation.
      Saying that life changes with just a new monitor is no exaggeration. The LG Smart Monitor Swing is the pinnacle of desk-terior – elevating not only function but also every task beyond the desk.
      Now it’s your turn to create a space that feels truly yours. Why not make it a “Home Swing Home”?
      Tailored for the European Market, Company’s New Range of Vacuum Solutions Offers
      Enhanced Convenience and Performance
      SEOUL, Aug. 28, 2025 — LG Electronics (LG) is showcasing four new vacuum cleaning solutions designed expressly for the European market at IFA 2025. The lineup includes a robot vacuum with steam mop, a built-in robot vacuum station, a stick vacuum and a wet-dry stick vacuum. Offering enhanced convenience, powerful performance and seamless design, LG’s latest innovations reaffirm the brand’s commitment to making everyday life easier for customers across Europe.
      Deep Clean Meets Everyday Comfort
      Significantly upgraded from its predecessor, the new LG robot vacuum raises the bar for home cleaning solutions with advanced features, functionality and the satisfaction of aesthetically blending into your home with its furniture-like looks. Its steam mopping capability effectively removes grease and liquid spills, while the freestanding, furniture-like docking station self-sterilizes the mop with hot water and steam, keeping it clean and odor-free after each use. With more than double the suction power of last year’s model, it delivers a deeper clean on both hard and carpeted floors.
      Equipped with an on-device AI chip, the robot vacuum recognizes a range of environmental factors – from dirt and dust to furniture and other household objects – enabling more precise navigation and cleaning. Its AI carpet detection system automatically returns the vacuum to the docking station to detach the mop when carpeted areas are detected, helping prevent staining and improving cleaning efficiency. Stylish yet practical, the docking station blends seamlessly with any interior for a clean, modern look. Furthermore, the new robot vacuum incorporates the LG Shield security platform to keep customers’ data safe and secure.
      Hidden Fit, Hands-free Experience
      Developed with European homes in mind, LG’s built-in robot vacuum station is designed to fit neatly into unused space beneath the kitchen sink, enabling a tidy and space-efficient installation. An auto-opening door, nearly invisible when closed, allows the vacuum to enter and return without user intervention, helping maintain a minimalist kitchen aesthetic.
      The built-in station features an air circulation system that dampens noise during automatic dust disposal, helping preserve a quieter indoor environment. It also offers a fully automated, hands-free experience with auto water supply and draining. In addition, a turbidity sensor monitors mop cleanliness in real time and automatically initiates washing when soiling is detected, ensuring thorough, efficient cleaning with less energy use.
      Enduring Performance
      Unlike conventional cordless vacuums that often lose suction due to clogging from pet hair and fine dust, LG’s new stick vacuum provides consistent, powerful performance. Its Micro Cyclone technology and new filter cleaning system delivers stable suction power every time.
      Building on its predecessor’s allergy-aware design, the model includes an auto dust disposal system that minimizes exposure to dust particles when emptying the bin. Additionally, it includes a compact, free-standing storage and recharging station with a small footprint, allowing users to conveniently place it almost anywhere in their home.
      Effortless Cleaning and Care
      LG is also introducing its new wet-dry stick vacuum, a product that meets growing consumer demand throughout Europe for a lighter, more convenient cleaning solution. Lightweight and easy to maneuver, it helps reduce wrist strain and fatigue during cleaning. The AI Roller Control function further lessens the burden on users’ wrists and contributes to overall ease-of-operation, ensuring the vacuum moves smoothly when pushed and pulled across different surfaces.
      Combining advanced capabilities of LG’s AI technology, the vacuum learns from users’ cleaning patterns to optimize efficiency. Its roller delivers powerful suction that lifts both liquid messes – such as sauces – and larger solid particles like cereal and pet food. Built-in LED lighting helps users spot debris in low-light conditions. For hygiene, the mop head undergoes hot water washing, steam sterilization and hot air drying – keeping the mop head fresh and the vacuum clean.
      “LG’s new vacuums are designed for European homes and lifestyles, delivering reliable performance along with greater comfort, hygiene and peace of mind,” said Lyu Jae-cheol, president of the LG Home Appliance Solution Company. “We are committed to introducing innovations that meet the diverse needs of our customers and create effortless ease and elegance in everyday life.”
      LG’s latest vacuum lineup and other home appliance solutions will be on display at the company’s IFA 2025 exhibition booth (Hall 18, Messe Berlin) in Berlin, Germany, from September 5-9.
      In today’s competitive world, having the freedom to create on your own terms is more important than ever. With that in mind, LG Taiwan recently introduced its latest IT lineup through a creative collaboration with renowned visual designer
      link hidden, please login to view – an initiative that celebrates the dynamic lifestyles of modern professionals.
      The showcase took place at a trendy café popular among freelancers, setting the perfect scene to demonstrate how LG’s technology fits seamlessly into both creative workflows and daily life.
      At the video editor’s station, LG highlighted high-performance tools designed for intense editing environments. The setup, resembling a professional post-production suite, featured the UltraGear OLED GX9 and the CineBeam S Ultra-Short Throw 4K Projector – demonstrating the depth, detail and precision of LG’s display technology.
      In contrast, the graphic designer’s space was bright, open and designed for maximum flexibility. With the LG gram Pro 2-in-1 and Smart Monitor Swing on display, this area showcased tools that offer creative professionals unmatched portability and versatility – ideal for capturing inspiration anytime, anywhere.
      Alongside the themed zones, guests explored a hands-on product and award showcase featuring the LG gram Pro 2-in-1, Smart Monitor Swing, CineBeam S and UltraGear OLED GX9. The display also spotlighted global honors from CES, Red Dot and iF Design Awards, reinforcing LG’s growing reputation as a leader in IT innovation.
      Opening the event, LG Taiwan Managing Director Jeong Yeon-kwan introduced the LG’s vision and philosophy of “Affectionate Intelligence” – an approach that puts people, emotions and usability at the center of technology. He emphasized LG’s commitment to creating solutions that don’t just perform, but connect with everyday human experiences.
      Designer Jyunccihli also took the stage to share how LG devices have helped elevate her creative process. From spontaneous sketching on the LG gram Pro to immersive design reviews on the LG Smart Monitor, she described how LG’s innovation continues to expand her artistic potential.
      Her newest trio of artworks – Spiral Nebula, Galactic Coordinates and Rotating Planet – draws inspiration from the cosmos and pairs with LG’s latest products: the LG gram, LG Smart Monitor, and CineBeam projector. Reflecting LG’s theme of “Light but Mighty,” the series fuses abstract celestial visuals with the spirit of innovation.
      “As with the universe, true lightness is not emptiness – it’s a hidden yet powerful force that upholds cosmic order,” says Jyunccihli. “To me, ‘lightness’ is a form of strength: intangible yet immeasurably profound, just like the universe itself.”
      To bring the creative energy to a wider audience, LG Taiwan launched the Creative Relay Challenge, encouraging the public to personalize designs using elements by Jyunccihli. Open to all, participants can use platforms like Instagram Stories to share their creations.
      Submissions are open through June 30, with selected entries eligible for exclusive prizes and the chance to be featured on LG Taiwan’s official platforms.
      Contributed by LG Taiwan
