Soundbar volume control not visible on screen and WOWcast connection drops
  • Popular Now
    • By Raphael Armin
    • By mesplint
      I have a LG 65QNED92AUA tv that has issues with the Bluetooth connection dropping off when connected to my earbuds. I believe the issue to be software related. LG has sent 2 technicians out to repair and the first technician changed the main board and Bluetooth transmitter which did not resolve the issue.
      There are similar issues with Bluetooth Connection from others.
      Since hardware replacement didn’t help and this is a known software-pattern issue, I would like push LG to specifically address it at the firmware/webOS level. I am unable to escalate to their software team and check if there’s a known patch or beta firmware for the QNED92 line.
      For some reason this line of questioning is not available with in LG customer service.
       Please help!
    • By MNW
      I've had Universal Control via the smart remote sucessfully controlling the audio (volume) for my LG OLED 48C1LB tv via my Sherwood RD-6118R amp for a while now; But following a power cut, the remote no longer controls the amp/tv volume?
      The audio IS still being played through the amp using the optical OUT/IN but I have no control of the volume
      I've removed and re-initialised the settings for this amp in Universal Control Settings but following the "success" message, the remote does not control the volume on the amp/tv.
      What am I missing?
    • By Dscottbellamy
      how can I fix lg soundbar model sn6y volume automatically going down after exactly 30 minutes if resetting, unhooking volume down button, drilling vent holes near motherboard, and running a cooling fan did not fix the problem.
    • By chris7ben
      The sound and picture are out of sync when screen mirroring from my iPhone 16 Pro to my LGQNED70A6A TV, using the internal speaker. I have tried all the recommended tips in the settings to cure the issue with no success. However, when I isolate the TV from the mains supply for 60 seconds and restart it, the syncing issue is cured but degrades after a day or so. My iPhone software is up to date and there is no firmware upgrade available for the TV. My LinkSys router has a full fibre connection. The only connection into the TV is the mains supply. Any help much appreciated. Thanks in advance.
