TV model 43UA740003LB which resets excessively often
Popular Now
By Cate-AppQuestion
Already tried turning the TV off and on and unplugging for 10 minutes.
There is no APPS tile in the horizontal tile row, so I can't load a third-party app like MLB.TV.
No luck with the WebOs tile, or the LG Content Store.
When I try the LG Content Store, and click on Apps inside that, I am only offered pre-loaded apps - 600 or so, but no MLB.TV.
Any help is greatly appreciated. Thanks.
By MaheshD
What is the latest LG web os support for TV model 49UJ752T-TB. Currently in this model of my LG tv showing 3.9.2, also neither I am not getting automatic updates not manual. Because of this certain apps are not available to my smart tv. Some of these apps are sony liv, jio, tata binge etc.
I req to plz help me how I can update lg web os for my TV model and which is the latest supported currently.
By MaheshD
By Damian1
After searching high & low, & also on the difficult to navigate LG website, I can't find which magic remote is compatible for my TV.
The model.of my LG TV is - 32LQ630B6LA
Can anybody assist, please?
Many thanks.
Aurelian
Bună ziua!
Am un televizor model 43UA740003LB, care se resetează excesiv de des , mai ales când este folosit pe streamming , dar îngrijorător, este faptul că se resetează și când este folosit că TV.
Mă puteți ajuta să înțeleg care sunt motivele pentru care televizorul se resetează atât de des?
Cu stimă,
Negritoru A
English Translation:
Hello! I have a TV model 43UA740003LB, which resets excessively often, especially when used for streaming, but worryingly, it also resets when used as a TV. Can you help me understand what are the reasons why the TV resets so often? Best regards, Negritoru A
Open in Google Translat
Edited by AlexEnglish translation added
