APPS Tile Missing From LG TV WebOs - 2019 model
Already tried turning the TV off and on and unplugging for 10 minutes.
There is no APPS tile in the horizontal tile row, so I can't load a third-party app like MLB.TV.
No luck with the WebOs tile, or the LG Content Store.
When I try the LG Content Store, and click on Apps inside that, I am only offered pre-loaded apps - 600 or so, but no MLB.TV.
Any help is greatly appreciated. Thanks.
  • Popular Now
    • By Ramesh Chand Vishwakarma
      Regards,
      MD/CEO
      Noida, UP
      +91 9910246766
    • By Raphael Armin
    • By stevef
      Since my lg-oled65c9pla auto-updated to WebOS 5.5, there is a new bug.
      No software has changed in my amp.  This is an annoying new bug in the TV software, I assume down to some CEC changes.
    • By FUNTIK
    • By FUNTIK
