youtube YouTube app problems, please help!
Popular Now
By FUNTIK
By FUNTIK
By Tosspot
I really love lg tvs hence I now own 3 but what I can’t get past that drives me crazy is any remote turns all tvs on of change Chanel etc and when I’m watching something and the wife changes channel in kitchen tv and the lounge tv chance drives me crazy I’ve unpaired and repaired individually and it still has the same problem
By bohatier
TV model: OLED55B13LA
Example:
By SNiPpy YiPpy
Hello all,
I believe this problem started after i accidently started and immediately cancelled the download of a app. After this I am unable to install or update any app evem after resetting to initial settings.
This should be the exact problem found here https://www.lgwebos.com/topic/1918-because-i-can however the solution seems to require a new update. Help?
Simon1973
I recently bought a 50NANO90A6B TV and so far I have to say it's a fantastic upgrade from my old Sony 40".
However, I've one small niggle problem (only had the TV since Sunday)... The YouTube app doesn't seem to want to work! it shows the logo with a spinny circle, then the logo starts again with the spinny circle... this just repeats over and over.
All other apps (iPlayer, Jellyfin, Plex, ITV, CH4 etc...) work as does the LGTV app, so the WiFi connection is fine!
I've uninstalled and reinstalled the YouTube app a few times, but it does the same each time!
Anyone know how I can sort this? any other suggestions for fixing it!
I'm currently using my Chromecast with GoogleTV for YouTube at the moment.
I'm in the UK by the way! And the TV is set to that, in all the relevant settings locations.
