LG 65UB950V (year 2015) with flickering and disturbed WebOs
Popular Now
By Ramesh Chand Vishwakarma
Regards,
MD/CEO
Noida, UP
+91 9910246766
By Raphael Armin
By stevef
Since my lg-oled65c9pla auto-updated to WebOS 5.5, there is a new bug.
No software has changed in my amp. This is an annoying new bug in the TV software, I assume down to some CEC changes.
By FUNTIK
By FUNTIK
alteraudiox
Hello, I have searched everywhere but it seems I am the only one facing this strange problem .... when I need to use whatsoever function like simply lower the volume or changing a channel the control works but the appairing webos, instead of showing the volume bar or the channell list, makes strange coloured patterns or flickering for few seconds, then it disappear and the tv goes on working with no issues; you may imagine that, apart using intuitive controls like volume or zapping channesl, it is impossible to get more settings because the list won't be visible on the screen .... any ideas ?
