My LG 43UM7600PLB TV does not sees the directories on the external USB drive
Popular Now
By Ramesh Chand Vishwakarma
Regards,
MD/CEO
Noida, UP
+91 9910246766
By LG OLED person
In "CMP settings": there is a huge list of vendors, IAB and Google.
You can deselect consent for those.
However when you go back, in the Google consent are all still enabled.
Reject All doesn;t work. Deselecting individually and clicking "Confirm my choices" doesn't work. The Google ones are back on.
That's really bad, GDPR.
oled55c24la, update 23.25.55
By JaneD
does AirPlay work on your LG projector? I can't get my PF510Q to show up in the Screen Sharing AirPlay menu on my iPhone.
Both the iPhone and the projector are connected to the same WiFi router (both wirelessly, no Ethernet). I tried enabling and disabling IPv6, restarting the router, iPhone and the projector, but still nothing showed up.
Then I connected my MacBook to the same WiFi network and enabled AirPlay Receiver on the MacBook. The iPhone could immediately see the MacBook and stream to it, so it looks like the problem is in the projector.
I should add that the WiFi router isn't connected to the internet, but there is no reason why AirPlay would need internet connection. After all, I was able to connect my iPhone to my MacBook via AirPlay without internet connection.
Thanks for your insights!
By Prakash Sahoo
Hi Team,
Prakash Sahoo
By Lesbo
Andy_Roider
As per the subject line, I have had a USB drive connected to my television for over four years, but for the past few days it has not been recognising the directories where my films and music are organised, and is displaying EVERYTHING in a single list of over a thousand files.
It is a 1TB drive (half of the maximum 2TB allowed) with a power supply, formatted as NTFS, and not completely full.
I have checked the drive and it has no bad sectors. I have tried connecting it to both USB ports and all the files are in the permitted format (avi, mkv, mp4, mp3, etc.).
I have also tried another 1TB drive, but the result is the same.
Do I need to reconfigure something in the television settings?
It would be a significant loss if I cannot resolve this issue.
Thank you in advance for your responses.
