On my LG 'smart' TV now for some reason I can now only watch the LG channels but not the fiber-optic programming on wi-fi . The HDMI 1 feed I normally use shows 'dark' on the Dashboard even though I can get the green checkmark on it. How do I reconnect it? The Dashboard shows my feed as ethernet/cable; which is wrong but efforts to correct it have failed so far.
Chemicals Industry
  • Popular Now
    • By Ramesh Chand Vishwakarma
      Regards,
      MD/CEO
      Noida, UP
      +91 9910246766
    • By stevef
      Since my lg-oled65c9pla auto-updated to WebOS 5.5, there is a new bug.
      No software has changed in my amp.  This is an annoying new bug in the TV software, I assume down to some CEC changes.
    • By andystaffs
      It seems our LG TV has done an update which has removed the "standard " BBC channels from the guide . After one day BBC2 has reappeared . The HD channels are present though . I've done a re-scan but no change . I've looked to see if we can move BBC1 HD (on 101) to Chanel 1 on the guide but doesn't seem to be an option.
      Anybody else have this problem and any cures ?
    • By Low Grade
      i always have to turn off the TV using the power switch (put on standby won't do) to view ''live tv'' channels again after watching LG Channels................any way to do that without powering off the tv completely ? 😟
    • By Lynne
      How do I sort the channels aphabetically please?  Especially on cable only
