Spurious message when pointer is activated.
Popular Now
By Raxo
Add the option to turn off mouse acceleration. I think I would fins it much easier to aim the pointer if I could disable it. I always disable it on computers. You can just add it next to the pointer speed setting under General > System > Additional Settings > Pointer Options
Two other settings I think would make sense to have would be a setting to disable the shake-remote-to-show-pointer feature. Although I like it I can sometimes find it annoying, so why not let the users decide. I always hate it when there aren't settings for things like these.
The other setting would be to disable the pointer completely as many users have written that they want to disable it.
By Batman
Serial Number:- 309MAUAGGP74
Programme Mode:- Antenna
Software Version:- 23.21.30
By u84six
By Speedemon
I have a UK6300 LG TV. It has always worked faultlessly. However it now will not show the pointer unless I restart it and then it only there of only for 20 seconds and then it is gone. The LAN cable notification constantly disconnects and reconnects. The Web Browser no longer opens on my selected page. The Software version is the latest and when I tried to manually update the software in case the auto update got corrupted it will not recognize the USB drive as having the software on it. The software browser version is 05.50.15.
Any ideas what to do. I have two other LG TV's and all work perfectly.
By duckie133
VERY ANNOYING!!!!!!!!!!
arthur payne
My TV is about 5 years old (Software version 04/63.25) and for the first couple of years it was connected via a Fetch Set-top box. After disconnection the Fetch box was returned to the supplier and the TV connected in the normal manner.
Ever since, whenever I activate the pointer, which is not very often now, there is a message on the screen "You can control your Set-top box with Magic Remote. Would you like to continue?" I have tried every possible way, short of a complete factory reset, to obviate this but without success. Can anyone suggest a fix? Any help/suggestions greatly appreciated.
