how to connect bluetooth to LG 32lm6300pla
Popular Now
By mesplint
I have a LG 65QNED92AUA tv that has issues with the Bluetooth connection dropping off when connected to my earbuds. I believe the issue to be software related. LG has sent 2 technicians out to repair and the first technician changed the main board and Bluetooth transmitter which did not resolve the issue.
There are similar issues with Bluetooth Connection from others.
Since hardware replacement didn’t help and this is a known software-pattern issue, I would like push LG to specifically address it at the firmware/webOS level. I am unable to escalate to their software team and check if there’s a known patch or beta firmware for the QNED92 line.
For some reason this line of questioning is not available with in LG customer service.
Please help!
By Fredrik Andersson
By hjetschko
Hi, I have a feature request for the sound out setting. I often connect my Bluetooth headphones to the TV. We don't use the internal speaker of the TV, we use the optical sound out setting whenever I don't use Bluetooth. It would make our lives a lot easier if the TV can remember the last sound out setting before connecting to Bluetooth and default back to this setting when the Bluetooth device gets disconnected. At the moment, each time I disconnect the headphones I have to go back into settings and change the sound out setting from internal speaker to optical again.
Thanks and regards
Hubert
By Barnkat
We're considering a new 77" LG OLED, and we cannot find an answer to this anywhere. Is it possible to use both an external soundbar (connected either with Optical or eARC) AND Bluetooth hearing aids at the same time, or is it limited to the TV's internal speakers and Bluetooth?
By elixir101
Why do I get this error message below on the TV, do I need to get a MAC address secured from EE, or is this a misleading error?
I have tried all the usual reboot, recycle, plug and unplug on both the LG TV and EE Smart Hub but nothing changes. Also tried Wired connection via Ethernet (LG TV acknowledges there is an Ethernet connection but still no internet):
TV: LG OLED48A26LA (2022) OLED HDR 4K Ultra HD Smart TV
Router: EE Smart Hub Plus
SOLVED: Parental control locks were on, with set schedule for wifi pause!
An Heuvel
We have a LG 32lm6300pla.
Software updates has not been on for a long time.
Can any type of bluetooth headphone be connected to the LG 32lm6300pla?
Or are strict bluetooth headphones required?
