Pikashow App
By Ethan Miller
Is there a way to fix this? There's a Samsung smart tv in my household that windows 7 recognizes and can cast to, but the LG WEBOS OLED TV is not even discoverable on the network and it is connected to WiFi. I know this tv is connected because in order to use AirPlay you have to be on the same WiFi. All my devices use the same WiFi connection. I can see all my devices except for the LG TV.
By LG user1
I can't open settings on my LG B9 55" either from the remote (results in black screen) or from menu system (same). Also, when I click on any streaming app, nothing happens although the buttons on the remote otherwise work. I would like to try a factory reset, but can't do this without accessing the system menu. If you know how to factory reset without the menu or otherwise know a fix, please let me know!
By Peyton Wheeler
Passion hours app won't show anything but the softcore content. Anyone had this problem?
By David Vaughan
I’ve tried Google, Facebook, and Amazon. All 3 have a blank black screen, no sign in rendered.
I’ve tried a manual login. Tells me to use google. I created an iCloud account to log in. I can log into LGs website. I cannot sign into the TV with the newly created email. It says there’s a temporary problem.
By desart1566
I noticed since the last update of WebOS, it defaults to a screen with apps along the bottom rather than HDMI1 as before on startup. Even after going into the input settings and selecting HDMI1, it stills defaults to the other screen on startup. When selecting HDMI1 on the inputs screen, it has a red dot in the corner, which I would assumes means that's the selected default. But again, this seems to be ignored this on startup.
Thanks.
