By
Matan Faragi
I'm not sure its the right place but at any case i will describe my issue here and maybe you will be able to help:
Recently I bought a a TV and a sound bar, and i have some issue from the moment i get the TV.
TV model - LG 55LB679Y with latest firmware version i have at my country (Israel) - 04.30.16
SoundBar - LG NB4540
the TV connected to sound bar by "wireless simplink" feature 'LG TV' and TV connected to My Wireless router.
every 5 - 15 minutes, i have sound drops / Cutoff / stooped / Interruption, seem like the TV loose connection to sound-bar for few seconds or something similar, it's happen from any AV source im using HDMI, USB...
and the local re-seller replace the sound-bar to a new one (same modal off course) and i didn't help.
i have try to troubleshot the problem in the last few weeks - but didn't succeed to solve it, and also the support / costumer service didn't have solution for this.
some steps i take when troubleshot this issue:
* different wireless configuration on router - different channels, SSID, Security - issue still persist.
* another wireless router - issue still persist.
* working with optical cable to sound bar - just for testing - working ok, but i need the wireless feature working this the reason i bought sound bar and TV from the same manufacturer.
* disconnect the TV from wireless network - looks like it's working ok, but didn't had chance to test it for long time.
from my point of view looks like it's issue with wireless device on TV not able to to work in parallel with soundbar and wireless network for some reason, It could be caused bysoftware issue on WebOS or Hardware issue with this TV model.
I really hope you be able to help me or throw some light on this case.
Kind regards,
Matan
Andrew Punch
So tv was working fine went to load and app today and wouldn't install, did a factory reset, reset the router, connected to phone hotspot
And can't get the user agreement to load. Even did the DNS 8.8.8.8 thing. Any advice?
Link to comment
Share on other sites
Top Posters For This Question
4
3
3
3
Popular Days
Jan 1
38
Jan 2
9
Jan 5
Jan 23
rickymartin 4 posts
Haylou 3 posts
Tommy Joyner 3 posts
Denkay 3 posts
Popular Days
Jan 1 2020
Jan 2 2020
Jan 5 2020
1 post
Jan 23 2022
1 post
Popular Posts
Tommy Joyner
Chatting with LG rep - He said: "The LG servers are currently down for maintenance, LG is currently working on fixing this and should be back up soon". That was a scripted BS answer - who takes
Tommy Joyner
No problem - I'll post here when I get more info. Hopefully, they will get this resolved quickly
Phil66
Thanks Tommy, after spending 2k on new things i was going to hit the bottle grrrrr.... try again tomorrow, Happy New year
48 answers to this question
