LG SJ800V Update 04.70.85 (Spa) lost HDMI ARC
By Roy Brown
By Alex
Automatic Firmware Update
Press the Home/Smart button on your remote to bring up your launcher bar.
Click the Settings icon in the top-right.
Choose the All Settings option at the bottom.
Choose the General menu from the left.
Scroll down, near the bottom of the list, and select About this TV.
From here, make sure Allow automatic updates is checked, and click the Check for updates button.
If an update is found, follow the steps on screen to download and install it.
By DavidSr
By Danilo Peixoto Ferreira
I wish I could control the volume of my LG TV 65NANO96SNA (webOS 4.50.71) using Apple TV 4K 3rd Generation (tvOS 17.3) with HDMI CEC (Belkin AV10176bt2M-BLK cable). The Apple TV has it on Settings, however, the TV does not respond to it. Turn on/off works. Volume control only works with IR. Could we prepare an update to support and fix it?
Juan Antonio Flores Castro
Problem Solved
Hello from Spain
My tv LG SJ800V 49" updated to 04.70.85 (Spa) and i lost HDMI ARC to sound bar
Link to comment
Share on other sites
5 answers to this question
