Audio output device issue
davidrenji
Hi all,
I have a 50LB6500-SF and I have an LG home theater connected using the optical port. I configured this with Simplink, So I can control the home theater with my tv magic remote control. In the audio setting I have the Audio Output as Optical, and it has been working great until last update. Now almost every hour, the Audio output changes to the TV Speakers by itself. So I have to go the audio out setting and changing it back to the Optical port, but then after a while it changes back to the TV Speakers and it's really annoying. I haven't changed anything, that's why I think is a bug that came with this update. Does anyone have this issue? Any idea of how to solve it? I tried removing and adding the home theater, but didn't fix the issue.
here are the more details about the tv:
LG 50LB6500-SF
Software version 05.00.45
webOS TV version 1.4.0-2513 (afro-ashley)
Thanks in advance!!!
Link to comment
Share on other sites
22 answers to this question
I've been having the same thing happen. I'm using the ARC output but everything else is exactly the same.
I thought it just happened when the TV turned off, but the other day it happened right as I was watching it.
Agreed it seems to be a bug with the latest update, as it never happened before.
If LG doesn't fix this I'm likely going to go back to Samsung soon...annoying.
Link to comment
Exactly this is happening to me. I upgraded the firmware of the theater but didn't solve the issue. I thougth of dowgrading the tv webos software to the previous version, but haven't found a way to do it
I was about to send for repair, because it is out of warranty. Now I'll wait if there are any solution, since other people are experiencing the same problem. I've also tough of downgrading the firmware, will try. Thanks!
Link to comment
If you find a way to downgrade the tv software, please let me know how.
Link to comment
Hey guys! I've found a post on a forum here in Brazil. A lot of people are experiecing the same issue. It is a firmware (05.00.35) issue. The new 05.00.50 solves it. Here is the link for the new firmware for manual instalation. At least for my 42LB6500 Brazilian TV:
Link to comment
Thanks! Hopefuly I can find the new version for my tv.
Link to comment
Just installed the version 05.00.55 (corrected, not .50) from that link and it seems to be solved! My TV: LG WebOS 42LB6500. I think this firmware is multi language, since I can choose the language and region on settings. Maybe you guys can give it a try! Hope it helps!
Link to comment
How did you install it?
Link to comment
1. Just format a USB falsh drive in FAT32.
2. Create a folder named: LG_DTV
3. Copy the firmware file inside the folder LG_DTV
4. Insert the USB on TV
5. Press install
6. Check on TV settings, general, about TV. You will see the firmware being installed, just like normal download over the internet.
7. When finished, turn off the TV and then turn it back on.
Link to comment
5. Press install
Thank you very much! I installed that version (05.00.55) in my 50LB6500 (I'm from El Salvador, but I don't know what's the tv region).
I've had my tv on for a couple of hours and so far everything looks good. I'll post another update after more hours of use.
Link to comment
    • By woof
      I have a couple of LG OLEDs in shared spaces, with external speakers, one via optical and the other via analog jack (confusingly named headphones). Whenever bluetooth headphones are used and then disconnected, the TV reverts to "internal" terrible audio. For non-technical people this is permanent. Do I have to train everyone to select the device from the long list or can I set a default?
    • By Aventiled
      Hey
      I have an OLED C3 evo
      A Pioneer amplifier is connected to the optical output.
      I want to connect Bluetooth headphones and use them at the same time as the amplifier.
      The thing is, I haven't seen such an option on TV. It is possible to play simultaneously with the Bluetooth headphones and the internal speakers on the TV.
      There is no option for Bluetooth and the optical port at the same time.
      Am I missing something here?
      Dani
      With the Addition of a 5MP Diagnostic Monitor, Company’s Comprehensive Range of
      Medical Monitors Now Boasts 13 Different Types of Display
      SEOUL, Apr. 12, 2024 — LG Electronics (LG) is accelerating its B2B medical device business, leveraging a full lineup of diagnostic monitors including the new 21HQ613D which was recently cleared by FDA for sale in the United States. Designed specifically for digital mammography and breast tomosynthesis, the 21HQ613D is a 21.3-inch 5-megapixel (MP) IPS diagnostic monitor that delivers high-definition radiological images and maintains consistent image quality through its internal front calibration sensor and calibration software.
      The 21HQ613D offers exceptional definition and brightness, its LG IPS display providing a resolution of 2,048 x 2,560, a luminance of 1100cd/m² and a contrast ratio of 1800:1. Suitable for reviewing various types of medical images, including breast MRIs, CT scans and ultrasound, the diagnostic monitor features an internal front sensor that removes the need for an external calibration device. With LG Calibration Studio Medical software, users can conveniently conduct DICOM calibration and quality assurance tests that comply with international quality control standards for medical monitors.
      The 21HQ613D also incorporates helpful features to assist users in the close examination of medical images, such as Focus View Mode and Pathology Mode. Controllable with either a mouse or keyboard, Focus View Mode lets users focus in on a specific part of an image, dimming the rest of the screen in order to highlight the selected area. Pathology Mode provides image clarity and accuracy as if looking into a microscope. Additionally, Multi-Resolution Mode (5, 3 and 2MP) makes it possible to quickly adjust screen resolution to suit the type of image being viewed.
      For a more productive and organized workspace, this diagnostic monitor supports daisy-chaining via DisplayPort connection. An easy and efficient way of linking monitors, daisy-chaining helps reduce desk clutter and simplify cable management. LG’s new diagnostic monitor also offers a comfortable user experience thanks to an ergonomic stand with adjustable tilt, height, swivel and bi-directional pivoting functionality.
      The diagnostic monitor’s five hotkeys improve user convenience by providing a quick and simple way to adjust settings or switch between modes. Meanwhile, the Presence Sensor helps to conserve energy, automatically shutting off the display if no motion has been detected for five minutes. The Down Light and Wall Light features enable users to read documents when the room is dim or completely dark, the former illuminating the desk or table surface below the monitor and the latter casting light on the area behind it. For a better viewing experience, the Auto Luminance Sensor automatically adjusts screen brightness according to ambient conditions.
      With the 21HQ613D, LG is targeting rapidly growing global demand for mammography monitors. According to an industry analysis report by Persistence Market Research, the global mammography market is projected to reach a valuation of USD 6.9 billion by 2023, with a CACR of 11.6% from 2023 to 2033.*
      LG’s expanded lineup of diagnostic monitors covers the major display needs of large hospitals. Along with the new 5MP model, the company provides 3MP monitor – primarily used for reading radiological images – and 8MP and 12MP products equipped with PBP (Picture-by-picture) mode, which allows simultaneous review of multiple diagnostic images. In total, LG now offers 13 types of medical monitors, including 5 diagnostic monitors, 5 surgical monitors and 3 monitors for clinical use.
      LG is committed to delivering advanced monitor solutions for the modern healthcare environment. In 2023, LG secured a significant contract with Centrale d’Achat de l’Informatique Hospitalière (CAIH), France’s hospital IT purchasing center, to provide a total of eight types of medical monitors. The contract, valued at EUR 10 million (approximately KRW 15 billion) over four years, represents the company’s largest agreement since entering the medical imaging device business in 2016.
      “Designed for reviewing mammograms and breast tomosynthesis, LG’s new diagnostic monitor is a high-quality medical imaging display offering easy management and useful functionality,” said YS Lee, vice president and head of the IT business unit of LG Business Solutions Company. “We will continue to provide the medical sector with cutting-edge solutions leveraging our innovative display technologies.”
      For more information about LG’s diagnostic monitors, visit
      link hidden, please login to view. Key Specifications:
      LG Diagnostic Monitor (21HQ613D)
      Display Panel Type IPS Size 21.3-inch Aspect Ratio 4:5 Resolution 5MP (2,048 x 2,560) Color Gamut (Typ.) NTSC (CIE1 931) 72% Brightness (Typ.) 1100cd/m² Contrast Ratio (Typ.) 1800:1 Response Time (Gray-To-Gray)
      5ms (GtG) Feature DICOM Compliant Yes Hardware Calibration Yes Display Mode Multi-Resolution Mode (5/3/2MP), Focus View Mode, Pathology Mode Video Signals Input Terminals DisplayPort x2, DVI-D (Dual Link) x1 User
      Convenience Dual Controller Yes Lighting Yes (Down / Wall) Hot Key Yes (5 keys) Presence Sensor Yes Physical Specifications
      Adjustable Stand Pivot (Bi-Directional) / Swivel: ±15° / Tilt.: -5°~20° / Height Range: 110mm
    • By Phil7108
      We recently subscribed to Paramount Plus to catch up on episodes we lost when our COX CONTOUR DVR died. Frequently when streaming an episode,the playback will suddenly freeze. If we try to go back, using the "undo" key, we can sometimes get the playback to resume, but it has rewound abp=out 10 minutes. After resuming playback, it will frequently freeze again. My wife is so frustrated, she wants to cancel Paramount. Any suggestions appreciated!
    • By cradge
      LG WebOS should be able to play mkv files with TrueHD audio codec format
