Reading exFAT formatted USB storage devices
mcored
  • 3 years later...
Most devices support FAT32 and exFAT as the major OSes( Windows,Linux,MacOSX) support them  almost as their native filesystem. Its strange to see LG TV support a proprietary and which is badly/not fully supported on all OSes: NTFS. This filesystem  (NTFS) should be the last to support on any other device thats not a Windows machine.
 My problem: I use a macos and can not write on NTFS devices. If I wish to view a 4K movie (64GB) , I have to pay an additional 20-30$ for a software that allows my mac to write/format NTFS files to a usb stick. The free-open-source software ntfs-3g its not good enough because it takes about 3hours to write a 4k movie (64GB) on a USB3.0 (UltraFit).
Great TV LG, but thanks a lot (sarcastically) for  taking from me more money and time to write my wedding on a USB3.0 so that I can view it on the TV.
Link to comment
Share on other sites
  • 2 weeks later...
  • 2 months later...
I too came here because I wan't to access some large file on a USB drive from my LG WebOS TV, and I use Mac so I can't use NTFS.
But I must clear up some misunderstandings:
exFAT IS NOT STANDARD on most Linux distributions!
Actually it dosen't even have a kernel module (only Fuse userland module) because exFAT is a licensed, close source and closed protocol.
It's not difficult to find this information, just look at wikipedia:
"exFAT (Extended File Allocation Table) is a Microsoft file system introduced in 2006 optimized for flash memory such as USB flash drives and SD cards.[5] It is proprietary and Microsoft owns patents on several elements of its design"
It was meant to replace FAT32 because of the filesize limitations. NTFS was doomed not feasible for small removable devices. But the biggest problem with NTFS is actually that it is closed source and support in other OS'es than windows is either made by:
a. buying and signing an NDA with Microsoft or
b. reversed engineered. Which is the solution Linux and Mac has chosen, and the reason Mac (and earlier Linux) defaulted to mount readonly. They didn't want to risk destroying anything.
So while I do agree with Microsoft that we need a new filesystem. I don't think a proprietary filesystem is the solution, for storage that is meant to be used in a lot of different devices based on different OS'es.
Could it be a solution to split the MKV's to multipart? I haven't tried but maybe WebOS will play them seamlessly.
  • Like 2
Link to comment
  • 5 months later...
  • 4 weeks later...
  • 6 months later...
27 minutes ago, Vietxitin said:
Thank for share, we use macOS and it doesn't support NTFS.
True, if you're wanting to write data to the NTFS volume using macOS, you need to install non-standard drivers.
But if you're wanting to pause live TV or record using the TV, you can get the TV to format the volume. Your mac can then *read* the NTFS volume without special drivers, although not sure what format the TV writes.
Good luck!
Link to comment
  • 5 weeks later...
  • 4 months later...
On 2/23/2019 at 10:43 PM, PeterV said:
What I did was connect the external harddisk to the Mac and install Plex on the Mac. After installing the Plex player on the LG TV I can watch movies using the Plex server on the Mac.
Works like a dream.
how fast is your internet speed? Do you connect through wifi or cable? What kind of movie files do you stream?
Link to comment
My internet up/downloadspeed is 100Mbit but all the computer and the LG TV are connected by wired network (100 Mbit or 1Gbit (don't really know)).
Normaly I stream 720p movies (because of the discspace) but it works without problems with a 1280p movie file. The filetypes you can stream can be found on the Plex website.
Link to comment
  • 5 months later...
  • 5 weeks later...
100% Mac household  - I needed an NTFS format for my external file saves on my Evolve HDMI capture device. This software does everything I need.
Microsoft NTS for Mac by Paragon costs just under $20 and will make it absolutely seamless to format NTFS or mount NTFS devices.
 - the latest is Catalina ready.
Edited by LeftCoastBoomer
clarity
Link to comment
  • 2 months later...
  • 3 weeks later...
+1 for exFAT, hard to believe that its 2020 and interconnectivity is still an issue.
UPDATE:
After some searching, found a good workaround. DNLA server can be installed rather painlessly and available from the LG TV with one-click!
The good thing it does not matter how your drive is formatted. (I can open my films from ext4 formatted disk on my TV).
Link to comment
  • 1 month later...
UPDATE:
DLNA server using minidnla on MacOS is great solution and works perfectly, thanks a lot Péter
I can now easily browse and stream movies with pause/ff/rw from my exFAT HD mounted to my Macbook Pro on my LG B9.
After searching for hours on a way to do this I am surprised to have such a great and simple solution. Thanks again.
Link to comment
  • 9 months later...
  • 6 months later...
  • 2 months later...
  • 2 months later...
  • 11 months later...
  • 6 months later...
    • By Puja aingh
      Dear LG TEAM
        Kindly resolve this issue
      My lG TV MODEL NO IS 32LK628BPTF
    • By Maksim Rabinovich
      I have a rooted LG C1. Is it possible somehow to read data from the light ambient sensor? I tried searching in /dev, /proc/, sys/bus, but there's a lot of clutter in there.
    • By Ginkgo_
      Hi all
      With my camera connected to my LG WebOS TV I recorded a video that was saved by default into the internal storage.
      I now want to extract it, and my first idea was to copy it into my USB Hdd, but unfortunately i have not seen any option for it. The only option I get when I access the video is to play or delete it.
      I now know it is possible to save the video directly on the hdd, but if possible I would like to get the one I have on the TV memory.
      Any idea on how can i do it?
      Thanks!
    • By Vishvajeet Patil
      Hey folks I wanted to know what is the RAM and Internal storage of LG OLED C2 55 inch TV? Android OLED TV of other brands now a days boast upwards of 32 GB internal storage. Wanted to know where premium LG devices stand.
      Debuting at KBIS 2022, Premium 48-Inch Wide French Door Refrigerator Delivers
      Unmatched Flexibility, Precise Temperature Control, Optimal User Experience
      SEOUL, Feb. 9, 2022 — LG Electronics (LG) unveiled its latest Signature Kitchen Suite built-in French Door refrigerator at the Kitchen & Bath Industry Show (KBIS) 2022, taking place in-person in Orlando, Florida (USA) from February 8-10. The 48-inch wide French-Door refrigerator, the latest addition to LG’s premium built-in kitchen appliance brand, boasts the flexibility and convenience of a convertible drawer and a sleek, functional design that delivers superior style and ease-of-use.
      The new refrigerator’s convertible drawer offers a wide temperature range of -21 to 5 degrees Celsius (-6 to 41 degrees Fahrenheit), offering five tailored storage settings for different items and different user needs including Chilled Wine, Fridge/Deli, Beverage, Freezer, Meats and Seafood. LG’s Lift and Go drawers and fully-adjustable door bins further extend the usability of the advanced refrigerator, making it easier to access stored ingredients. The individual freezer drawers provide more usable space for keeping frozen foods at a low, stable temperature until they’re needed.
      The Signature Kitchen Suite Built-in French Door model incorporates the versatile Signature Fit Integrated Design, which allows for proud – with the front set forward – or flush installation with the surrounding cabinetry. The refrigerator’s drawers align perfectly with standard countertop height, ensuring clean, uninterrupted lines that elevate the kitchen environment. LG’s sophisticated French-Door refrigerator is available in stainless steel and panel-ready options.
      Thanks to its dual compressors and metal interior, this large-capacity refrigerator provides the ideal conditions for preserving all kinds of foods. As well as minimizing temperature fluctuations to keep stored items fresher for longer, the model is ENERGY STAR® certified for its conservative usage of electricity. What’s more, the new eco-conscious model also employs lower Global Warming Potential (GWP) R600A Iso-Butane refrigerant to reduce environmental impact without sacrificing performance.
      With a host of thoughtfully designed and seamlessly integrated features, the Signature Kitchen Suite 48-inch French-Door refrigerator provides a truly user-friendly experience. Through Wi-Fi connectivity, users can easily manage and monitor the fridge remotely via other smart devices. What’s more, the ThinQ Care, LG’s popular Proactive Customer Care, offers users helpful maintenance tips to keep the appliance performing at its very best, offering advice about potential issues before they occur. Convenience is further enhanced with Dual Ice Maker with Craft Ice, soft yet illuminating LED lighting, a built-in water dispenser with filtration, easy-to-read digital controls, adaptive defrost and special modes including Ice Plus and Sabbath Mode.
      “Our Signature Kitchen Suite refrigerator being showcased at KBIS this week features LG’s award-winning innovations for unmatched versatility, outstanding performance and stylish design,” said Lyu Jae-cheol, president of LG Electronics Home Appliance & Air Solution Company. “We’re pleased we could be a part of KBIS this year because there’s no comparison to seeing this impressive refrigerator in real life.”
      For more information on Signature Kitchen Suite’s full portfolio of built-in kitchen appliances, visit
